CudaChris67
looking good! are you going to be ultimately installing trim around the cutouts, recess everything, or flush mount everything?
I thought I would post a dwg of the heater valve layout. I received the second valve and a wiring harness from Vintage Air. Here is what it will look like. Getting the NO valve was the key to this.
Andrew
After talking to alot of shops, Mike Ware at muscle motors in Lansing will get the contract. he wants to punch out a 340R3 block to 472cuin with 750 hp I said so long as it will run92 octane Im good with that. Ill be removing the 545RFE and putting in an electric 6speed TCI, I have worked out the electronics for engaging the manual mode and paddle shifting from the steering wheel.
Its just a matter of the funds. Soon enough.
Andrew
Now Im conflicted, Ive heard many nightmare stories about Ryan's work. Let's put this in perspective.
The build Im requiring will cost between $15,000 & $20,000. There has to be a machine shop that will produce a quality product and stand behind it. There will be a contract, and default of that contract will be dealt with very severely.
Lets equate that to a proctologist with a beach umbrella.
That being said,if you have done this before it should not be a problem.
Let me put this out there, If you have blessed me, Ill shout it from the mountain tops. If you have screwed me, Ill shout it even louder!
The check has not been written, so its all on the table.
Andrew
Missile,
"Your electromechanical shouldn't be an issue. ---as long as your grounds are good you should be ok.."
Also- is your galaxy a CB only rig, or is it a HAM rig as well? Whats the output power?
The Galaxy is 11meters only, no SSB, 4 watts, set up for maximum modulation...etc. by the shop I bought it from. I did check the seal (right before I cut through it) and there was a new one there with the shop ID and initials, so someone was inside. The RX seems to be well tuned, the chatter here is all out on IH35 by the truckers.
Grounding: :cheers::cheers::cheers:
Each compartment of the car has a master grounding buss connected to the battery, while the body of the car is connected to the system, the body is not the conductor.
first pic is the engine compartment buss bar the second is the trunk's.
