Birth of the Blue Missile
Here is the bulk of it from my load calc sheet:
Exterior lighting
LED running lights
headlights
FLIR headlights
Engine compartment
electric fans
electronic ignition
starter
Passenger compartment
interior lighting
HVAC
Digital gauge cluster
fire suppression system
rear spoiler
CB radio
linear amp
hood scoop
exhaust system compressor
after burners ignition circuit
RADAR detector
FLIR display
LASAR jammer
rear defroster
electric windows
CD player
data logging computer and display
Andrew
Sorry Ive not been up to posting for a bit.
I hope the list was helpful.
Since there was no response to the list, I hope I have not offended someone.
I know this is not your normal build, but I never said I was from your planet.
Over the past few days I have recreated the FLIR enclosures out of 1.25"x1.25"x1/16" stainless tube stock. I sectioned one half of each piece to create the needed taper and cut the rest out with a 4" grinder.
They are much straighter and painted up don't look "Cheesy".
Andrew
Exterior lighting
LED running lights
headlights
FLIR headlights
Engine compartment
electric fans
electronic ignition
starter
interior lighting
HVAC
rear spoiler
CB radio
linear amp
hood scoop
RADAR detector
FLIR display
LASAR jammer
rear defroster
electric windows
CD player
Andrew
Radar detector laser jammer is this a car or a fighter jet
Posted via Topify using iPhone/iPad
Prostreet,
based on your name, you enjoy getting together with your buds and showing off your car and what it can do. Very cool!
I on the other hand, enjoy putting the hammer down on the open road. Who among us wouldn't like to be able to go 200mph in total darkness right past the RADAR gun and still have the operator say- What the hell was that?!
Just a thought---not that I would ever do that.
Andrew
Ill let you know when I order it. Im still conflicted, so I have not pulled the trigger on it.
Andrew
Maybe I should part out the Duster and sell you mine ..of course the HDK has to go with it for the custom front parts to work. Hey, it's got that 170 AMP alternator you need !!!!!!!
Ross I have a HDK.
In the mean time, I got the heater lines run to the bypass valve and I have the condensate drain installed. It exits into the front wheel well rather than the engine compartment.
Ive had the AC in and out a half a dozen times, maybe another dozen more to go. Doing a final bundling on some of the wiring to get it out of the way of the unit.
I also got the AC bulkhead connectors installed.
Andrew
Ross I have a HDK.
Andrew
I knew you had a HDK, I was trying to sell you my motor....
Just a quick update, I now have the AC unit in place and have solved the spatial conflicts with the center console. I did not have to move the wiper motor, and as a matter of fact the wiper linkage was a greater obstacle.
Andrew
I lowered the seats 1" and shoved the passenger seat as far inboard as I can get it. It was too close to the roll cage for my comfort.
Andrew
I got the Innovate wideband air fuel gauge ordered which starts the data logging chain.
I also got the color coded led version of the Valentine1 remote display ordered for the Heads Up Display. When these all get here I can pretty much button up the dash and move on.
Andrew
All of the major pieces are in place. The A/F gauge is a little under lit, and the Valentine remote display wont light up without the main unit, so that will wait.
Sorry about the out of focus situation, my cell phone camera does not deal well with these sort of shots. The light from all the LEDs seems to mess with it.
Andrew
Yes, go back to the beginning of the thread and read the story. All the adventures in the land of kudzu are in your home town!
Andrew
This thing is in beleiveable and about that showing off I never ever show off I always follow the rules of the road 100% of the time all the time
