58plaza
Active Member
Not sure how to figure out what gear ratio is currently in place. No ID tags to help decipher.
Plaza sedan is bottom line 58 (or near it) and I'll bet it's lighter than some 70s A-bodies. Aluminum head 408, and a 904, would be a couple hundred pounds less than an all-iron poly, and iron powerflite.
Edit: Plaza is even down-scale of a savoy in 58. Two door sedan probably the lightest 58 Plymouth you could buy. Frankly, I'm surprised it has a poly and auto, I would have expected a six cylinder flattie and a three on the tree.
Edit: shipping weight 3,385 lbs. Curb weight: 3,560 lbs.With the exception of the business coupe, this particular model was about as cheap as you could get and it’s the last year the plaza model was offered. I can’t confirm the drivetrain is original but the VIN would lead me to believe it is. No arm rests, but it has a radio, dual speed windshield wiper with fluid sprayer, sun visors, cigarette lighter, etc.. A bit of a strange duck.
And a aluminum head and intake 408 and aluminum trans will save 150 lbs off that, compared to your current all-iron stuff.Edit: shipping weight 3,385 lbs. Curb weight: 3,560 lbs.
If it's stone original, it MIGHT still have a tag on one of the center section bolts with the ratio on it. I wouldn't bank on it. Other than that, you'll have to determine if it's open (99.9% probability) or sure grip.
Both rear tires off the ground, neutral, if sure grip, turn one tire, the other will go the same direction. Open, the other tire will turn opposite, or not at all.
Further instructions and methods for counting the gear ratio are available on you tube. Good luck.
ction
Your response seems a little uncalled for. We (or I) wasn’t calling him out at all. I merely stated that given his own description of the intended use of the vehicle the choice of engine was questionable. Do you think it would be wise to put 465hp in front of a trans that’s designed to handle 150 and a rear that could hold possibly 400? It’s not “the height of stupidity” to suggest something different that may be a better option for a given set of circumstances.Hey Guy,
Put whatever you want in your car. It’s the height of stupidity for guys to call you out for a high horsepower engine in a Mopar that’s not for racing etc. WTF? A 408 stroker sounds like a great idea in that car!
i'll add to the concerns of the supporting cast that, surprise! 465hp motors don't like to be soft pedaled around town and can sometimes suffer from lack of throttle response down low and be a little fickle in the driveability department.Your response seems a little uncalled for. We (or I) wasn’t calling him out at all. I merely stated that given his own description of the intended use of the vehicle the choice of engine was questionable. Do you think it would be wise to put 465hp in front of a trans that’s designed to handle 150 and a rear that could hold possibly 400? It’s not “the height of stupidity” to suggest something different that may be a better option for a given set of circumstances.
this is kind of a slippery slope and dependent on a lot of different factors and personal choices.Yes, she’ll be a driver, but not daily. If replacing the trans, how would I know which one to choose? A quick search online generates numerous options, which vary widely in $$. Will the push buttons currently used for the power flite work with a 727 trans?
My 414 small block stroker is 500 hp 500 tq at the crank and throttle response off idle is instant and hits hard and fast zero delay. I can drive mine around like grandma stop and go traffic putting around its just purs along just fine. Has a custom ground hydraulic roller from Indio Motor Machine in CA they know how to get it all to work right together.i'll add to the concerns of the supporting cast that, surprise! 465hp motors don't like to be soft pedaled around town and can sometimes suffer from lack of throttle response down low and be a little fickle in the driveability department.
to me 465 hp says street/strip car or a weekend bruiser, not i wanna cruise to sonic for a tots and shake.
I see what you are saying, but how many of us have ever said, "Wow, why would he want to stuff a 426 Hemi in his 67 Barracuda?" or "Nah, I don't want any more HP because I am not going to race my car".I don’t get it, if it’s not being raced or driven hard, why do you need a 465hp crate engine?
S'why I put him on ignore a long, long time ago.Your response seems a little uncalled for. We (or I) wasn’t calling him out at all. I merely stated that given his own description of the intended use of the vehicle the choice of engine was questionable. Do you think it would be wise to put 465hp in front of a trans that’s designed to handle 150 and a rear that could hold possibly 400? It’s not “the height of stupidity” to suggest something different that may be a better option for a given set of circumstances.
Thanks to all for the feedback. I’d like to avoid cutting on the car or going away from the push button trans but it sounds as though that may not be possible if I opt for a crate engine. The mechanic who worked on my car last fall doesn’t like to fabricate or make major modifications so I may have to find another shop.this is kind of a slippery slope and dependent on a lot of different factors and personal choices.
things that will make the decision more challenging are if you want an overdrive transmission, if using the factory pushbuttons is a deal breaker and if you don't want to cut on the car or are not able to do minimal fabrication work.
no matter the answer, you will 100% need to upgrade. the question to what should you upgrade to will be determined by those factors.
If you are paying to have all the work done and you want to avoid heavy mods to the car then you should consider the keep the poly advice. The money saved on the blueprint will be big $$ to get the rest of the car sorted out. Your total $$ will be much lower modding the poly (stroker even) or waiting until a prebuilt car comes available with what you want. Good shops are very expensive. Cheap shops are even more expensive but you don’t realize it up front.Thanks to all for the feedback. I’d like to avoid cutting on the car or going away from the push button trans but it sounds as though that may not be possible if I opt for a crate engine. The mechanic who worked on my car last fall doesn’t like to fabricate or make major modifications so I may have to find another shop.
that would be my play as well. i'm a sucker for factory duals on 50's cars.If it was mine, I'd keep the poly (with maybe a 2x4 for the visual) and stick an A500 overdrive under the floor, and something like a SG 3.73/3.91 in the back.
99.99% chance you'll have to fab a trans cross member, 100% you'll have to fab a trans mount. either of which i'd classify as "basic hot rod fab" so if you have a vice, torch, BFH and a buzzbox it's doable.Thanks to all for the feedback. I’d like to avoid cutting on the car or going away from the push button trans but it sounds as though that may not be possible if I opt for a crate engine. The mechanic who worked on my car last fall doesn’t like to fabricate or make major modifications so I may have to find another shop.
