Bostonian 71 demon
Tonight, I tackled several things on the car. First, the upper ball joints arrived, and they’re even better than I expected. Initially, I thought they’d be heavier than the old ones, but they’re only 0.2 pounds more. I could easily make up for that with titanium hardware or, worst case, shave off a few threads on the lathe. Next up was reaming the spindles to the right size and keeping everything square, which I handled on the drill press. Then I welded in the lower control arm mounts. After that, I went back to the ball joints and sorted out the new 772 cups. I wrapped up the night by pulling the windshield trim and the windshield so I can move forward with removing the dashboard and tackling the cowl and firewall.
Great work! Thanks for taking us along with this journey. Can't wait to see it finished
In the words of Jeremy Clarkson, I did a thing! But seriously, I pulled the dash out tonight. Now I’ve got to decide whether to go with fiberglass or stick with steel. On top of that, I got the new cups fitted to the upper control arms. The car's also scheduled for the chassis shop, so I’ve got a hard deadline — all my work has to be done by the end of April. After that, it’s off to the body shop by the beginning of August to let the real pros take over. And as if building the Hemi wasn’t enough, everything will be ready in time for late 2026.
Plus, I ordered a fiberglass dash that weighs just 4 pounds, and I’ve got all the vintage contingency stickers I could ever need lined up. I’m also drawing heavy inspiration for the paint job from these Pro Stocks, so it’s going to look amazing once the new paint and lettering are done."
"I got a lot done this morning, removing small brackets and unnecessary parts, and tackling lighting holes that no one will ever see once the project is finished. I also received some tech help in the mail today from Herb McCandless, which will really help me make more progress. But before running out of welding gas, I managed to fill the holes in the firewall and made and attached the aluminum filler plates around the cage. Now I will switch gears to fill the vent and wiper holes in the new cowl, then focus on the transmission opening." before blasting the floor boards. I drew inspiration from the red-light bandit.
Holy **** .
I said earlier it will be a 100% an accurate nostalgia pro stock everything short of acid dipping
I'm going for sorta nostalgic pro stock and I really really appreciate the extent you're going and showing us how it's done. Great job !!!
