As long as the air flow is there between the heads and intake, the compression ratio can be afforded to be a little low. More the merry of you can, but being limited in more than 1 area can be a killer. The combo can not be compromised to many times and still meet the expected desired results.
If it needs to run on pump gas, get what compression you can.
