AC pics for a member who PM'ed me about it because he needs the header clearance:
As you can see, I chopped some of the front cover off (chopped more off since then). I bolted the top back bolt to the block (had to open up the AC arm hole a bit), and braced the two front arms to front cover bolts. Only need to brace 3 of the 4 arms for a good install. Ends up close to the spool mount on mine- angled it out a bit and it was fine.
Sanden 7176 compressor.
