RAMM
A new customer contacted me and wants to build a 408 and use these heads that he has "way too much $$$ invested in". Customer ships them and I decided to baseline them. These heads were previously serviced/refreshed and I flowed them as I received them OOTB.
Flow @ 28" 4.06" Bore 2.055"/1.6" valve diameters:
.1 62.9
.2 120.3
.3 179
.4 225.7
.45 245.3
.5 259.3
.55 266
.6 269
.7 259
I decided to clean them thoroughly and re-valve job them considering it looked like there was room for improvement. I also took a deshrouding cut which added .060" between the intake valve and chamber wall. A 30* backcut was also added to the intake valve in an effort to bolster the somewhat weak low valve lifts. After results:
.1 65.9
.2 135
.3 192.6
.4 232
.45 250
.5 265
.55 271
.6 266
.7 261
This is my first set of Indybrocks I get to look at and can see where they could use proper porting and the 93.5+% throat size is hilarious. Porting these is not part of the plan or budget. J.Rob
.1 62.9
.2 120.3
.3 179
.4 225.7
.45 245.3
.5 259.3
.55 266
.6 269
.7 259
.1 65.9
.2 135
.3 192.6
.4 232
.45 250
.5 265
.55 271
.6 266
.7 261
