HYD HYDRAULIC SLAVE CLUTCH ACTUATING KIT
Details
Hydraulic slave clutch actuating kit mounts between the side cover on any A833 tranmission and the stock clutch fork, pulling the clutch fork back when pedal is pushed. Recommended only when stock, mechanical linkage cannot be used because of clearance issues with exhaust system or applications where motor/bellhousing are not in the stock location. Kit includes transmission bracket/pivot assembly, slave cylinder, master cylinder with resovoirs, hoses and instructions. Some engineering required to mount master cylinder through the firewall or fabrication of a bracket to mount off of the pedal assembly frame.
Price: $399.95
