My "new" '74 Duster- or why I need a project like a hole in the headWhat do the rear sliders look like? Any pictures?
i thought we all wereVery nice.
Remember I'm old.
the shackles do the same thing when they swing. the sliders are just smoother and eliminate the side to side lever affect of the shacklesI'm just spitballin........but what I was wonderin is, if the sliders are somehow letting the springs extend, instead of lifting the body....and planting the rear axle. Maybe that the sliders are letting the springs "just straighten out" if you will. If that makes any sense. At any rate, "SOMETHING" is keeping the body from rising......and the axle from planting the tires. It's just not happening.
Try the lower hole on the front spring mount bracket. It will lower the IC. The rear ride height will increase which might make the IC change a wash, but worth a shot. You may need lower ride height rear springs. I would also loosen the rear shock extension a lot. The car has no separation on leave. The front end doesn't appear to have much travel either. Needs 5" or more of front travel. Caltrac Abody cars have to be one of the most unforgiving suspensions ever. The 20" front spring segment makes the IC WAY TOO SHORT, which is the root cause of the issues people have. Nobody in their right mind would build a 20" ladder bar or have their 4 link intersect at 20" for the same reasons.
I agree with loosening the rebound butTry the lower hole on the front spring mount bracket. It will lower the IC. The rear ride height will increase which might make the IC change a wash, but worth a shot. You may need lower ride height rear springs. I would also loosen the rear shock extension a lot. The car has no separation on leave. The front end doesn't appear to have much travel either. Needs 5" or more of front travel. Caltrac Abody cars have to be one of the most unforgiving suspensions ever. The 20" front spring segment makes the IC WAY TOO SHORT, which is the root cause of the issues people have. Nobody in their right mind would build a 20" ladder bar or have their 4 link intersect at 20" for the same reasons.
I agree lots of people using the CaltracI get that. But if you notice from the pictures, the sliders don't allow the springs to hang down as far as the shackles.......whether that has anything to do with it, I don't know.
I do know this. I KNOW there are LOTS of Mopar cars using the leaf spring rear suspension and running fast. There are also lots of Mopars using Caltracs and running fast........and planting the tires a LOT harder than this car. He's got "something" going on and I don't see a lot of other people coming in here trying to discuss it, so that's what I am doing. Throwing ideas out.
A ladder bar won’t fix it. A 32 inch IC that’s what, 12 inches up isn’t that much better than what you have.
If you can’t get what you have to work, get a 4 link.
FWIW, you need WAY more bump in the shocks, probably need to slow the extension way down, put some air in the tires and see if you can use the shocks to control the hit AND keep the tire from bouncing back every time it gets hit.
What you are seeing is the tire getting hit, then bouncing back, then getting hit again and repeating.
Once you tame the back end down, you’ll probably need to go back up front and and tune it. Probably more travel, a bit slower to keep it from shocking the tires.
I’m not done trying to get it to workMy 68 fastback has the same set up on it , and it didnt do the bouncing thing, only had 10'' wide drag radials on , virtually no front end lift , it went straight and didnt bounce at all , altho it was slipping the tires. Knew a guy with ladder bars , his duster would run low 9`s w/ ladder bars , and threy didnt change the front spring segment length either----------??
Yes,I’ve been from 12-16 lbsVerify pinion angle looks to me that the axle is wrapping and unloading. Could have thrown off angle with your lowering blocks. I’m assuming you’ve mad several hits with various tire pressures with same results.
DamnThe SLR on the stick stockers is closer to 15.
System and going fast
But not many people hit the tire with a lot rpm most people are using the foot brake
And if they are using a transbrake they are leaving at most 3500
I’m leaving at 5000rpm with not a ton of power
Sorry, question, SLR?
Thanks
11.7Sorry, question, SLR?
Thanks
The car is actually faster when I “run at the converter “why the need for the rpm? Its very unlikely it will make the car any faster. Very unlikely.
I had a 9 sec(3350 pound) S/S spring car. 28 by 10 tire.
No clamps on the leafs, moved the RPM around on the 2 step until i found the sweet spot(4100) and the car would hook anywhere.
Off the foot or brake, the 60 foot and ET were virtually identical. Only issue i had was car occasionally got out of hand regards wheelstands.
Dont give up, your issues are fixable.
My Dart has the same set up only with Viking DA's, the fronts were sent to Afterworks and revalved for no prep surfaces. I had it out a couple weeks ago and it was doing the same thing although not as violent, probably because I was foot braking leaving at 2000. After I tightened the rebound two clicks on both ends of the car and it left clean. My buddy was in the water box behind me and he said the car just left, no squatting or raising. It went 1.40 60' on that pass, with some more tuning it should be in the .30's.
