Dartfreak75
Restore it, Dont part it!
Ok started on degreeing my cam this morning and im no where close I have done it over and over and over... and keep getting the same results so I think I'm doing in constant. I used lunatis instructions they are straight forward find TDC rotate until you get .050 valve lift on the number 1 intake and compare it to the card. That's where my trouble comes in. My cam card says 2 degrees BTDC. I'm getting nothing btdc my dial is still at zero up until I im past tbc! At .05 lift im 22 degrees ATDC! I don't understand what im doing wrong i don't think the came is off 180 because then the lobe would be on the other side wouldn't it? Thanks i appreciate your input
