Lol I actually thought the same thing! I'm in the intake. The 2nd one on #1
Check....the first lobe on the front of the cam is #1 exhaust. The second lobe is #2 exhaust. The 3rd lobe is #1 intake.
I haven't checked it in the overlap stage but I did check it at tdc on the compression sequence and they are both closed and apear to be even. I will roll it over 180 and see what it looks like. The cam has 4 degrees advance built in when installed straight up so im assuming it should be advanced.What I would just to see if you are even in the ballpark is roll the engine to TDC firing, and then rotate it 180 degrees so you are on overlap.
Then look at the lifters. If the exhaust lifter is higher than the intake, the cam is retarded. If both lifters are the same height the cam is installed split overlap, or straight up. If the intake is higher, the cam is advanced.
Also, I’m not sure what you have the dial indicator riding on, but I would find an old pushrod or something and cut it off above deck level and get the DI up away from the block like that.
The other thing is I look at the intake centerline first. Once that is correct, I verify what then at .050 number is.
Cam timing is simply doing nothing more that putting the cam in the correct location relative to the crank.
I care way more where the cam is at max lift than I do what’s happening at .050. They should both match the cam card, but lifter bank angle anomalies can affect that .050 opening number.
Some guys were themselves over that number. Some guys claim their lobes are so different that the ICL doesn’t matter. It does matter.
I used the dial indicator similar to the video tmm posted i set it up and got it as close to TDC and possible then backed it off about 5 degrees set the dial went up to .25 then back around the other way to .25 the subtracted the difference. It was about 2 degrees off I moved my wheel 2 degrees and did it again and it was just about perfectHow are you trying to find TDC? Use a piston stop. That's the best, most positive way.
Thanks man I thought I was until this now I feel completely lost again haha. I don't understand it I can't figure out what I'm doing wrong. And that drives me insane. I worked 12 hours last night and have to work 12 hours again tonight I was up till noon trying to figure it out never did! I will work on it more in the morning. I just keep racking my Brain trying to figure it out. I almost feel that Its me and I missed a step somewhere or doing something wrong in the degree process I just can't figure out whatYou are learning a lot about engines dartfreak, the knowledge you are gaining will pay dividends in the future.
It's all interesting, and fun learning as you go through the steps. Feeling of accomplishment when you get it right.
Thanks I understand what you are saying something is off on mine then because I'm not getting any lift until I'm past tdc. I can watch the lobe coming around and the lifter is near the base when its at tdc i checked it at over and over again and it doest start getting lift until after tdc. To answer your questions I have the dial on the circle of the lifter and its nice and tight I set it at zero on the heel of the lobe and its constant I have rolled it over probably 50 times or more and it always resets back to zero on the back side of the lobe. And I don't think the setup there is at fault. However it is possible its something in the wheel. Its one of the printed ones that I glued to a piece of cardboard. The I cut cardboard circles to shim between the crank and crank bolt to squish fit it on. It moves with the crankshaft and I am getting repeated tdc readings. That's what is messing with me. If I can get a continuous zero at tdc on both sides how can I be 22 degrees off? If the wheel is at fault.Are you certain the wheel is moving exactly as the crankshaft moves and not slipping? Dial indicator probe centered firmly (and straight!) in the lifter cup and reading movement as soon as the lifter moves with no hiccups? Lifter planted firmly on the cam lobe?
If everything checks out--all that's really left that I can think of is the set is marked wrong or you're not reading it at the right spot.
Starting with the wheel at zero, on TDC compression stroke, that valve will be on the back of the lobe, so zero on the dial. It will stay at zero until you come all the way around to approaching TDC on the exhaust stroke (cam sprocket dot at 6:00) and as you get close to TDC that's when the dial should start moving. So! If that's what you're seeing, but it's still off that many degrees at the .050" lift my money's on a mis-marked sprocket...advance the cam a tooth and re-do. Yeah you'll have to start over, but....
Remember it's where the timing ends up that matters, not how the dots are or aren't lined up..
Keep at it!
Im actually considering buying me some checking springs and try doing it off the valve. Then I can use a piston stop. I'm pretty confident I have my tdc correct tho.If you use a positive piston stop, it will help you understand it even more.
Thanks man I appreciate it. I am learning. I am trying to learn and do it right. I'm not gonna quit until I know it's right. That's just how I am lol. I have one of those addictive ocd personalities I can't quit on something until I'm satisfied with it and right now I'm not lol. I really appreciate all of yalls input.Cam degreeing is not an easy task to do first time around, and you don't need to completely understand it here and now. Confusing yes, just consider this your first step in understanding it and you can look into it some more at a later date.
You pretty much have it right now with your single keyway cam, the way you have it timed.
Like yellow rose says: Top Dead Center on #1 on compression stroke, then roll it over 180° and look at the lifter heights, if even then it is Straight Up Timed, just like you want. If one lifter is higher than the other then something is out of whack, advanced or retarded one way or another.
I just like to see first time engine builders use the single keyway timing gear and time it Straight Up just like factory, Not needing the degree wheel.
Using the multi-keyway timing gears and trying to advance your cam another 4° is where you want to start checking things with a degree wheel so it does not end up
way way off.
The degree wheel is a way to check everyone's machine work, making sure both keyways were cut into the right spots on the timing gears and dots in the right places, and that the cam keyways and lobe centers are where they should be for the application. Bringing it all together to give you the events that you want to see take place.
So yeah, you are doing good not to worry.
I have shimmed the wheel in between cardboard disks I cut out and its bolted on with he crank bolt. Its wedged I between the crank and the washer on the bolt. Once again tho if that was the issue how could it be right at tdc every time both ways? I can go Clockwise to TDC and its zero! Go Counter CW to TDC and its still zero. So I don't understand how it could be moving. That was my first thought also! I will try the positive piston stop and set it to TDC that way. I don't think I'm 20 degrees off TDC but I will try it.Also, what are you using to turn the crankshaft? What type of device and how is the degree wheel mounted? Unless you spent a good bit on a crank socket, I can almost guarantee you that your crank socket is moving on the crank. There aren't but one or two on the market worth a crap.
Sorry missed your post earlier im using the one marked intake. The 2nd one on the #1 cylinderShow a photo of which lobe you're using.
It is but I made it that way i drilled it out under size so its a pressed fit on the boltIs the hole in the wheel the same size as the bolt? I've rarely seen "that". But it sounds like if it is, you should be accurate. I would still recommend a piston stop.
Yes I know I was just saying I'd like to check the lift at the valves as well probably won't until I get my issue now fixed tho.Why do you have to buy anything? I'm lost. You can use a piston stop now. Don't you have the heads off?
But I'm getting constant tdc readings. If the tdc was off it would not be zero both ways. Im not being hard headed here I will try the the stop way I just don't think it's that. The wheel hasn't moved and im still at tdc all the way on both sides of the stroke. If my tdc was 22 degrees off it wouldn't be zero both ways would it?OK, then you should be ok there. The only other place a discrepancy might be is not using a piston stop. For like the fourth time. lol
For example if I had it zero tdc in the compression stroke then spun it around to where #6 is at the compression stroke and #1 is tdc the wheel should read like 44 degrees if I was 22 off. Because you have to split the difference. If you go one way its is 20 and the other way its 24 than 22 would be true tdc so you move the wheel to 22 then spin it back around and get 22 again then remove the stop 0 is true tdc! Correct?But I'm getting constant tdc readings. If the tdc was off it would not be zero both ways. Im not being hard headed here I will try the the stop way I just don't think it's that. The wheel hasn't moved and im still at tdc all the way on both sides of the stroke. If my tdc was 22 degrees off it wouldn't be zero both ways would it?
