POS Dakota
Anti-Socialist
Wow. sorry bro.
After having this happen to me twice, I only run roller cams.
You cant go wrong.
You cant go wrong.
Rice is right, did you pre-oil?
If I were you,I,d get ahold of Brian at IMM engines(Cali.)He should be able to give you answers to all your questions and help get you back together.Ask about a roller cam.Mine is .631 lift @.050 252@258 @106So any suggestions on a new cam and cam bearings? Can the bearings be changed without pulling the engine? I think probably not, but I'm tired of R&Ring engines in this thing.
"Pre-oil" meaning you primed the engine with the oil pump priming tool using a drill?
64, I see Hughes supplied the heads. Do you have paperwork that says what the installed heights of the springs are? I'm not a Magnum guy but perhaps Brian can help me here... The Magnum installed height is typically shorter unless the valves are longer. Around 1.600" with stock valves. The 1122 spring at an installed height of 1.830 has about 335lbs at .600 lift according to Hughe's site. The dual spring they recommend (1111) is installed at 1.80 and has the same 333lbs at .600 lift. If they set the spring heights up for even the longer Chevy valves (.100") you're still way short for that spring. Meaning the pressures will be WAY higher. I doubt it would coil bind, but the pressures may be too high for the cam. If you verified all you said (and I don't doubt that part) then there's got to be an issue with soemthing you couldn't verify.
On cleaning teh block... Yeah, take it out, strip it to bare, wash it with soap and brushes, and reassemble the whole thing. Iron dust went everywhere and not cleaning it is a fast way to wipe out everything else down the road. Oil changes and flushes don't cut it when it's all through it. I'm doing the same with an engine that ate a timing cover now. It sucks.
Physhy I bought a cam from Hughes last year and they sold me the same springs you provided the link to. After I got home I checked them to verify the pressure and they actually have more pressure than their rated at. Mine show 150 lbs on the seat and 350 over the nose. That's a lot for breaking in a cam that's as aggressively ground as yours. IMO Hughes should have told you those springs were too stout for break in. Even if they were what they were rated at that's a lot of pressure to break in a cam that aggressive. JMO
....bingo.
I was told the same thing 10yrs ago when I bought my hughes cam/lifters & springs.
they don't tell everybody that they figure in 'spring break in' or 'spring cycling' which is where the spring upon cycling with heat/compression loses 7-9lbs , btw that is what dave told me back then, that they start out heavy to compensate for the psi lose after spring break in.
130 psi seat would have worked, but 150+ on a fast ramp is disaster city.Ahh.....That explains why mine tested so high.
Cool thing about double springs is you have pull the inners and drop the seat pressure down 20'ish psi for break in.
I love how they talk about lite weight beehive springs saying they are like titanium valves.....Yep their sure easier. Going with the high pressure beehive's caused me to have to buy an extra set of lighter weight springs to break in my cam.
I'll take the lighter valves 1st, unless they hit rockers er sumthin.
Lighter valves/'retainers' and lighter lifters are the key here.jmo
Did you know that hughes solid lifters weigh 20 grams a piece MORE than mp solid lifters? -320 grams extra to bounce around..maybe thats why they really need that beehive.
if it wasn't for their rockers...they could drop off the face of the planet for all I care.
LOL!! After my last experience with them I feel the same
When you lose a cam, you have to tear it completely apart, remove all galley plugs and CLEAN your *** off!
Then use new bearings, possibly new rings (if metal was on the bores, it will cause the moly to peel off the rings and you'll have issues later on)and most likely cam bearings.
This is why I stress to our customers to dyno the engine. That 550.00 is worth it in the long run. When you try to break the engine in while it's in the car, you can have other issues that prolong the startup and break in procedure allowing metal to transfer from lifter to lobe or vice versa.
It would be a good idea to check the spring pressure when you get the heads off. Also check lifter bores for less than perfect fit.
The engine needs to be started up timed very close to ideal and ran immediately to 2500 rpm. Then I adjust the timing to about 38 or so to keep ex. temps down and run it there for 20 min.
After that, I idle it down, reset timing where I want it and adjust the floats and idle of the carb.
Hope it goes better for you next time.
Brian
Ive been considering building a metal stand with some gauges to break-in my future engine rather than the in-car break-in..
