the directions don't say anything about notching that area? thats pretty lame.
I agree
It should probably be included in the instructions. I've seen worse instructions than what QA1 provides though. All of these cars are a little different, and how much you need to notch that mount depends on your ride height, alignment, and whether or not you've modified the bump stops any. The QA1 instructions kind of make it sound like an easier operation than it really is, "bolt it on and go" kind of deal when adding tubular control arms is really a pretty big modification to the suspension. It's a relatively simple addition, but it changes a lot of other things, especially clearances.
Hotchkis includes the info in their instructions, even though the Hotchkis arms are probably less likely to need the mounts modified than the QA1's because of their design. You can actually see that in the picture, the UCA is actually lower than the clearance they cut on theirs.
