I have a 69 Dodge Dart Swinger that I would like to run in SS/JA with a 340 combination. I am told the biggest issue will be getting the AVS 4612S to work. It needs to "massaged" but staying within the NHRA rules. Who is out there that has had success doing this?
Thanks for the reply.
That "Massage" is more like re-engineering" the carb.
Do you need to stay with 4 actual bbl.'s or there stock diameter butterfly size?
hi, the stock carb does not perform very well on a stocker or super stocker motor!! you can not rework throttle shafts, thin throttle blades, or polish in venturis, , fuel passages can be enlarged, rejetted, air bleeds reworked, they measure bores, and blades and shafts. a properly setup carb is usually worth
about 2-3 tenths. good luck.
