Carter Carburetors ~ Tech and Specs
Carter Carburetors
1966 Plymouth/Dodge ~ 383/325 HP
1966 Chrysler Imperial ~ 440/350 HP
1966 Plymouth/Dodge/Chrysler ~ 440/365 HP
AFB {4130S; Manual} and {#4131S; Automatic}
Rated @ 566 CFM's
Throttle Body Sizes .......... 1 7/16" x 1 9/16"
Venturi Sizes ................... 1.186" x 1.563"
This Carter AFB was utilized for the 383/325 HP, as well as the 'big'
Chrysler 440/350 HP, and Plymouth/Dodge 440/365 HP 'Big Body' as well as the 'Police Pursuit Vehicles'.
Stupid is as stupid does. You ever heard of parts swapping? What if you need a certain size metering rod or jet? Now you know what to look for in other makes that used Carter Carbs. Damn. Special Ed?
Tell me about it! Does it really matter THAT much that you have to use only carb parts that came on a MoPar? Or not use them at all?!?! Holy Gez - Us!
Keep posting this info!
Carter Carburetors
1965 Chevrolet ~ 327/300 HP
AFB {3721S; Manual}
Rated @ 665 CFM's
Throttle Body Sizes ......... 1 9/16 " x 1 11/16"
Venturi Sizes .................. 1.250" x 1.562"
Primary Jets .................. .995"
Secondary Jets .............. .067"
Metering Rods ............... .063" x .069"
This AFB was regarded as one the best Carter Carburetor combinations
for the 327/300 HP Chevrolet engine.
Though rated at a tad lower in CFM's than the 1962 thru 1964 AFB {680 CFM}, this Carburetor was an excellent unit for the 327/300 HP Engine.
Performance Recommendations
To 'richen' this AFB by {12.3%}, {.071"} Secondary Jets were
recommended.
For better 'Cruising Power', a {.104"} Primary Jet and {.076"} Metering Rod
were recommended, which made the AFB {1.9%} Leaner.
For improved 'Power', a {.104"} Primary Jet and {.055"} Metering Rod
were recommended, which made the AFB {31.3%} Richer.
Carter Carburetors
1964 Pontiac GTO ~ 389/325 HP
AFB {#3647S; Manual} and {#3649S; Automatic}
Rated @ 575 CFM's
Throttle Body Sizes ....... 1 7/16" x 1 11/16"
Venturi Sizes ................ 1.186" x 1.563"
Primary Jets ................. .092"
Secondary Jets ............. .089"
Metering Rods .............. 16-167 {.0695" x .063"}
This AFB {575 CFM} is built on the {610 CFM frame}. It can easily be
converted to {610 CFM's} by replacing the Hot Idle Compensator
with a 1963 and earlier Hot Idle Compensator {#169-43S}
Also, with the Rochester Tri-Power Unit {767 CFM's}, this 389 Engine
combination put out an additional {+23 HP} to 348 Horsepower.
That sweet! thanks for the 273 info! huh,thats wild auto/man all years had the same jets/rods... hummm. cool.
Carter Carburetors
1967 Plymouth/Dodge ~ 273/235 HP
AFB {#4294; Manual}
Rated @ 470 CFM's
Throttle Body Sizes ......... 1 7/16" x 1 9/16"
Venturi Sizes .................. 1.063" x 1.250"
Primary Jets ................... .089"
Secondary Jets ............... .073"
Step-Up Rods ................. 16-403 {.069" x .058" x .065"}
Low Speed Jet ................ #66 {.033"}
Humm ill halfa mic my metering rods. i thought they used 3 step rods in the oem afb's & avs's? I know for sure mine are no dout 3 step rods in there.
Carter Carburetors
AFB {#4294; Manual}
Rated @ 470 CFM's
My Error 'HiPo 65'. Now Corrected.
Carter Carburetors
1965 Buick ~ 400/325 HP
AFB {#3922S; Manual} and {#3923S; Automatic}
Rated @ 575 CFM's
Throttle Body Sizes ......... 1 9/16" x 1 11/16"
Venturi Sizes .................. 1.186" x 1.562"
Primary Jets ................... .092"
Secondary Jets ............... .089"
Metering Rods ................ 16-167{.0695" x .063"}
This AFB could easily be converted to {610 CFM's} by swapping out the
Hot Idle Compensator with the {#169-43S} unit.
Carter Carburetors
1965 Buick ~ 425/360 HP 'Dual-Quad'
AFB {#3645S}
Rated @ 610 CFM's
Throttle Body Sizes ...... 1 9/16" x 1 11/16"
Venturi Sizes ............... 1.186" x 1.562"
Primary Jets ................ .092"
Secondary Jets ............ .070"
Metering Rods ............. 16-286 {.0675" x .063"}
Carter Carburetors
1966 Plymouth/Dodge ~ 426 'Street Hemi'
AFB {4139S; Front Carburetor} and {4140S; Rear Carburetor}
Rated @ 600 CFM's
Throttle Body Sizes ................... 1 7/16" x 1 11/16"
Venturi Sizes ............................ 1.186" x 1.563"
Primary Jets {Front Carb}........... .101"
Secondary Jets {Front Carb} ...... .083" {Left Side} ~ .101" {Right Side}
Primary Jets {Rear Carb} ........... .101" {Left Side} ~ .083" {Right Side}
Secondary Jets {Rear Carb} ....... .101"
Metering Rods .......................... .070" x .047"
Low Speed Jet {Front Carb} ....... #65 {.028"}
Low Speed Jet {Rear Carb} ........ #65 {.028"} Manual Transmission
Low Speed Jet {Rear Carb} ........ #65 {.031"} Automatic Transmission
Power Piston Spring ................... Orange
Note: The Carter AFB's {#4139S and #4140S} were advertised as being rated at 625 CFM's.
Note; The 'adjusted' rating was {-4%} less than the 'advertised' rating.
Carter Carburetors
1967 Plymouth/Dodge ~ 383/280 HP ~ {Dart GTS 383 and Barracuda 383-S}
AFB {#4298S; Manual} and {#4299S; Automatic}
Rated @ 537 CFM's
Throttle Body Sizes ............... 1 7/16" x 1 9/16"
Venturi Sizes ........................ 1.186" x 1.313"
Primary Jets ....................... .089"
Secondary Jets {#4298S}..... .0695"
Secondary Jets {#4299S} .... .068"
Metering Rod ....................... 16-404 {.063" x .051"}
This Carter AFB on the A-Body 383/280 HP Engine was listed as a
'restricted' Carburetor at 525 CFM's, due to the smaller {1.313" Secondary Venturi}
Recommendations were to step up the Secondary Jets {one size} for
Street-use {#120-371 ~ .071"}.
And, to go up {two sizes} for Track-use {#120-175 ~ .073"}
Carter Carburetors
1967 Plymouth/Dodge ~ 440/375 HP
AFB {#4326S; Manual} and {#4327S; Automatic}
Rated @ 728 CFM's
Throttle Body Sizes ........... 1 11/16" x 1 11/16"
Venturi Sizes .................... 1.437" x 1.586"
Primary Jets ..................... .098"
Secondary Jets {#4326S} .. .080" Pump Side ~ .065" Opposite Side
Secondary Jets {#4327S} .. .077" Pump Side ~ .065" Opposite Side
Though advertised at 750 CFM's, the calculated rating was at 728 CFM's
for the big Throttle-Bore AFB.
The Carter AFB #9755 {replacement Carburetor}
Primary Jets ................. .113"
Secondary Jets ............. .107"
Metering Rods .............. .071" x .047"
Carter Carburetors
~ 1962 Plymouth/Dodge ~ 413/410 HP and 413/420 HP ~
~ 1963 Plymouth/Dodge ~ 426/415 HP and 426/425 HP {early Carbs}~
Technically, the Max-Wedge 'Stage I' AFB Carburetor
AFB {3447S}
Rated @ 600 CFM's
Throttle Body Sizes .......... 1 7/16" x 1 11/16"
Primary Jets .................... .098" {120-163}
Secondary Jets ................ .082" {120-158}
Metering Rods .................. 16-51 {.068" x .050"}
When using the AFB {#3447S} for a Single-Carburetor on the Small-Block Mopar.
1} Re-adjust the full-throttle arm, as it comes from the factory set at
15* before closing at W.O.T.
2} Change the Primary Jets to .089" {120-159}, as the Jets are too rich
for the Small Block.
3} Change the Secondary Jets to .095" {120-167}, as the Jets are too lean
4} Change the Metering Rods to 16-75 {.0635" x .053"}
5} Replace the Secondary Clusters with {58-151S} and {58-152S} from the
1963 {mid-Year} and 1964 ~ 426 Maximum Performance Engine AFB #3705S
Carter Carburetors
~ 1968 Plymouth/Dodge ~ 383/335 HP ~ 383/330 HP ~ 383/300 HP ~
AVS {4401S; Automatic}
Rated @ 630 CFM's
Venturi Sizes ................ 1.186" x AV
Primary Jets ................ .089" {120-489; Long}
Secondary Jet .............. .089" {120-389; Short} {Pump Side}
Secondary Jet .............. .086" {120-386; Short} {Opposite Side}
Metering Rod ................ 16-564 {.068" x .065" x .055"} {Pump Side}
Metering Rod ................ 16-565 {.065" x .063" x .055"} {Opposite Side}
Carter Carburetors
1965/1966/1967 ~ Plymouth ~ 273/235 HP ~ '273 Commando'
1965/1966/1967 ~ Dodge ~ 273/235 HP ~ 'Charger 273'
1965 > {#3853S; Manual" and {#3854S; Automatic}
1966 > {#4199S; Manual} and {#4120S; Automatic}
1967 > {#4294S; Manual} and {#4295S; Automatic}
AFB
Rated @ 470 CFM's
Though advertised as a 'special' 500 CFM AFB, it was basically a
good performing 4-Barrel for the small-cubed 273.
Several NHRA Stock-Class Racers flow tested this AFB, and were able to
generate a {517 CFM} air-flow at W.O.T.
Correction: 66 carb is a 4119S
tmm
Carter Carburetors
Rated @ 537 CFM's
Excellent thread and info. Thanx. I now know what my 4299S is for. I know you are still building the list, but do you have nfo on a 9510S? I have this one loitering as well.
Carter Carburetors
1966 > {#4119S; Manual} and {#4120S; Automatic}
AFB
Rated @ 470 CFM's
Correct T-M-M,..............:cheers:
Carter Carburetors
AFB {9510S}
Rated @ 500 CFM's
Throttle Body Sizes...... 1 7/16" x 1 11/16"
Venturi Sizes .............. 1.186" x 1.250"
Primary Jets ............... .086"
Secondary Jets ........... .095"
Metering Rods ............ .065" x .052"
The #9510S is a superseded version of the Competition #9500 Series.
The #9510S comes equipped with GM Linkage and an Electric Choke, and
with provisions for an EGR unit.
This Carburetor was designed as a replacement Carburetor for Low-Performance '327' Chevrolet engines.
This may be a long thread! Didn't Carter make something like 500+ AFB calibrations alone? Phew! :)
Carter Carburetors
1968 Plymouth/Dodge ~ 340/275 HP
AVS {#4424S; Manual} and {#4425S; Automatic}
Rated @ 630 CFM's
Throttle Body Sizes ........ 1 7/16" x 1 11/16"
Venturi Sizes ................. 1.186" x AV
Primary Jets .................. .089" {120-489}
Secondary Jets {4424S}.. .095" {120-395}
Secondary Jets {4425S}.. .098" {120-398}
Metering Rods {4424S} ... 15-581 {.065" x .063" . 055"}
Metering Rods {4425S} ... 16-160 {.0645" x .062" . 055"}
The same combination was used for the 1969 Plymouth/Dodge ~ 340/275 HP
AVS {#4611S; Manual} and {#4612S; Automatic}
Rated @ 630 CFM's
