LowDeck451
Agree. I know that I (amateur) have learned a few things about Magnum heads from this build. Thanks RAMM.I hope you continue sharing the build. Not everyone needs 600+HP
Thanks for the results. I was never a big fan of the as cast head myself. Seeing these numbers helps me/us understand how and where they make power.Full results of flow test
IMO, better than rival.LA heads for me too! Better shaft stability with shaft mount rockers to name one benefit. Once ported correclty can rival magnum heads. Only drawback can be open chamber.
234 @ .445 is pretty good for the little bit of work done.
This will make a very nice street head.
The as cast head is still pretty good at making power, even unported just look at the Magnum crate program. I'm interested to see what this engine with this mild camshaft can muster. Maybe I should have spent more time on the heads? I do believe I will see 420 lb/ft out of this though. J.Rob
Just sharing what our valve job looks like on the intake side for our 2.02 valve...also use a rather large back cut on the valve too.
View attachment 1715041193 View attachment 1715041194
If you spend more time on the heads then you defeated your purpose. At some point you have to say this is it.
As I said had to turn a 143 tooth external balance flywheel into a 130 tooth external balance flywheel. Can't wait to test this one. J.Rob
Well....thank you guys! I only posted those pics because that cutter is one I came up with that works really well on these heads...when I first started messing with them I did some flow testing with different angles and widths starting with a 2" valve and eventually settling on the 2.02 size. The extremely generous top cut + angle is what got me from the low 250's to the high 260's...on the unported version. Also, the generous back cut + angle is what allowed the heads to keep pulling up to .650 lift and only lose about 5 cfm from .650 to .700. This seat cut doesn't work on std. open chamber heads or Eddy heads though. Jesse, I look forward to the 5.9 results too....this project keeps taking small turns, in part to Johnny, so it's not quite what I wanted to do but I believe we will crest 450HP with it. Should be ready for dyno session next month if all goes well.A perfect example of a damn nice valve job.
Very very nice. I like that you didn't skimp on the top cut!
Ok, I have to ask....why are you doing this^^^^^^^^^^^^^^^^^^^^^^^^^^^^?
Is this some one off deal you can't buy, or do you just like doing stuff?
First I already had this 143 tooth 360 flywheel = free. I also had a 130 tooth ring gear. The large 143 tooth flywheel is incompatible with the small bellhousing I am going to use. I also don't like the 33 lb weight penalty vs 22 lbs for this version. I do like doing stuff also. J.Rob
Got it. Using what you had. I understand.
I thought maybe you just liked doing things to say you did them. I used to do that. Then I hit 40 years old and said screw it.
I do like recycling parts when you can.
A mere child! LOLI'm 40+ yrs now and have to push myself. Use it or lose it becomes all too real.
We're getting off track here. Just fire up the damn thing so we can hear it run!
Now if you could mount the Hall effect distributor to the crankshaft snout, that'd be something. Maybe use a 4-cylinder one.
Skip that, skip that, I'm dragging you off track again.
May I ask... are those the G3 Hemi valves your referred to earlier? Is there anything special about them?
Where'd you find the intake now... back in stock at your suppliers?
