stixx
Funny is he made highest VE with the "lean condition".
RAMM,
I noticed the lean AFR condition up to 4500 rpm. Was that only part throttle up to then? I would not think so. The #'s could be off, why so lean?
Marion
Hah! Now you're talking. It gives me hope for the stroker. The 6530 is what we bought for the next dyno runs.
Still this is fairly lean which indicates the carb is too large for this little lung , which it is. Wish I had a 650 on hand. J.Rob
I must have missed the "locked distributor" mention. I have to be honest and say I'm a little surprised that the small cam is doing this well. I wouldn't have guessed this high.
what size carb is on it now?
i went back and did a quick look, didn't see what carb for sure, think i might remember you said it's a 950hp...
now bolt on one them westech special carb spacers and shoot the moon,..get ya past that 400 mark easy!!
I just read through this start-to-finish and it was great... I want to take the Magnum top end from my busted 360 and build basically the same as you did but on a 318 instead. Same kind of bottom end, zero-deck flat tops etc. but with something like this cam Voodoo Hydraulic Flat Tappet Cam - Chrysler 273-360 268/276 - Lunati Power; the lift with 1.6 rockers would be like .527/.547" though, you think that would be excessive for how these tend to stall past .500"?
I was thinking about just leaving the heads alone, they're untouched iron Magnums but this thread convinced me to get a good valve job done. I'm OK with reusing the factory Magnum valves and Hughes springs/retainers though no G3 Hemi valves lol.
What do you think the HP/Tq curves would be like in comparison to your 360? I'd guess around 40-50 less lb-ft, and mayyybe 20 HP less if I'm lucky?
Very solid numbers for such a small cam, showing that you used the given parts to their best!
Looking at the cam specs I have got a question (kinda stabbing in the dark): isn’t is usually said that the Magnums have a good exhaust port that doesn’t need a lot more duration, if any, than the intake?
I noticed that your other 360 you showed recently (?) had like 224/224° duration and made very good numbers (with different cylinder heads, I admit). So does the Cheepy really need the split on intake/exhaust … or was the cam just one you had on the shelf, or could it have made even better numbers with a ‘square’ cam?
Now I'm curious to see how it does with the new rockers.
My build is close to yours. same pistons. a little less compression. a little more lift and EQ heads with 1.6 roller rockers.
We'll test anyone's engine for $550/day. But in a town where the sign reads "Population 1081" before the big mine layoff, it's mostly our own stuff.
I have a 350 core with some Vortec heads sitting out back. Never tested them though.
A while back I alluded to a 383 Chevy we built. Local customer requested 450 HP for his show truck because he could get that on a budget of X$ from an outfit advertising on the internet.
Ah, well, we kept to the budget, and.............with a carburetor he got 392 LB-FT @ 3,000 rpm, 484 LB-FT @ 5,000 rpm and 518 HP @ 5,800-6,000 rpm
With the Holley Terminator FI not fully through it's learning curve, 399 LB-FT @ 3,000 rpm, 472 LB-FT @ 4,900 rpm and 511 HP @ 5,800 RPM.
10.1:1 compression, Pump gas, Victor Jr intake, AFR 1034 heads, custom street solid roller 236/242 .564/.570 113 LSA 109 ICL, 1.5 Scorpion roller rockers, and using the long tube headers for his truck.
I'm still a 383 Chevy novice because that is the sum total of my 383 experience.
great info! can you tell us more about the mods needed on the distrib. etc. would not both setups have the same amount of advance at peak horse rpm? you can borrow my 625 AVS but I do not think a smaller carb will help peak horse. maybe a thinner oil and HP1 filter, what u running? maybe that small cam will like 1.6 rockers, but we have never gained much going up on ratio when the cam is "right"
Might have a new head on the market in another year...won't be AFR though.I hear ya on the small town reality. I've tested more than a few 383's and every time they have any kind of AFR head they go well over 500 HP. Love Scorpion rockers for value. Youre results from carb to EFI mimic my own. Check the averages--carb was WAY better in my case even thought the peaks were very close with EFI.
I would love to see an AFR SBM head someday but I doubt it will happen. If I had some serious funds I would handle the pattern making and cover the cost of a run at a foundry and then handle the final machining--but alas this is one of my better dreams. J.Rob
