cleaning a toilet help needed!
got a pumice stone from Ace & made some progress tho the stone ain't even gonna touch the thicker stains in the pic & since chemicals in this small efficiency apt wouldn't be safe I may have to just call it good. thanks guys for the comprehensive/interesting! help/info. RR
I am curious if you tried the the Lysol stuff I posted; did it not work for you? It was like magic on mine and it was the first time I tried it.
all of the Ace hardware stores were out of it but their computer shows that Walmart has it so I will pick up a bottle
pardon the delay. after one app of Lysol letting it soak & some more scrubbing with the pumice stone here is where I'm at. (cant get a pic to load but will keep after it). EDIT got it!
Put some Sno-bol or similar product in there and let it soak for many hours or a day or two... Keep going back periodically with a toilet brush to remove it as it loosens and breaks down the grime...
I could post some toilet jokes, but that would be shitty...
I gotta second what Mr. Ddaddy said. But, I would try the CokalaCola first. Then CLR and/or vinegar. I use Iron Out too.
You can get stronger vinegar too, like 45% strength. I have well water like that that. Mine is loaded with ferris iron, ferric iron, mixed with very hard water. Any harder it would be ice.
What kind of douche bag would use vinegar??? :lol:
I attacked it again. same as before I cant get the latest pic to upload into the computer but I will keep after it and it looks much much better. I think I am going to call it good. thanks very much guys for the comprehensive! insightful! interesting! plans of attack and I a 90% vegetarian and I will post the pic when I get it figured out. thank you! RR
