M
Ms4speed
Guest
i have done a 440/727 swap into a 71 dodge dart, i used B-body hp manifolds. it all fit except i had to modify the steering column and cut it way back to clear the driver side exhaust manifold, this was no problem because this car has a console mounted shifter.
my question now is: because a 383 is shorter and narrower than an RB block....would it be possible to put a 383/727 into a 68 dodge dart and still keep the column shift? i have to have the column shift because i have a bench seat that i really like.......if i can't keep he column shift then i will stay with a small block, just though i would ask because i would like to make use of a 383 i have.
