Hi all.
Just like to recap about these cams being noisier than normal. It has been discussed that the agressive ginds are to blame for this. Is this absolutely correct?
If I was to use Comp Cams "matching" lifters and springs would this help? Reason being is that I did not use any other Comp Cams product except the cam itself. Has anyone done this?
I would like to hear some feedback on different combinations used out there.
I am starting to think I have a problem due to this noiser valve train I have with this new engine.
My combo is Comp Cams XE274, Eaton Hydraulic lifters, Elgin (120Lbs seated, 270Lbs lifted springs), Adjustable cast steel roller rockers made by a local machinist hear down under. 7.300" push rods.
Kind regards at all.
Billy D...
Billy D...
