100% agree!I would like to see a W2 with victor vs pro dominator vs m1 dual plane . Curves should be wildly different.
I have yet to see any M1 dual plane performance results .
It may be interesting to see how much valve the CNC heads, though. IIRC, SM listed their CNC heads at 2.02 and Pro Comp as 2.08. Maybe see what flow and dyno results show with some 2.055 and 2.125 valves.Would love to see this. Would be awesome to see ported SM vs. ported W2 vs. Promaxx shocker CNC vs. trickflow …and bloomers if a set could be sourced.
Haha. One can wish right?
The promaxx cnc and ported SM might be redundant since they’re both the same casting.
I've got a brand new standard port M1 single plane I could loan as well as a set of ProMaxx 171 (non-CNC) heads. Have an extra 340 block that I could "loan" if I can drop it off. Don't care to ship something like that.I’ll start by saying Hell Yea do it. And offer help if I can. I have a M1 W2 single plane I can send for testing if it helps.
That sounds like my engine.I'm running a bit more lift though. .668/.668.The parameters would be a well prepared 408 or 416, forged pistons, 11-1 compression with a nominal 64cc chamber, solid roller in the 250-260 @.050 range duration, .640-.650 lift, and a rpm target of 3500-7000. The questionable part will be trying to keep intakes and headers similar enough to not skew the basic trends
i personally don't. i think that a combo that is more in reach of us average joes and typical pocketbooks would be quite beneficial.Well, might change it up a bit, I realized I have a rotating assembly allready done for a stock stroke 360 I was going to enter in a build contest that never materialized. Anyone have any issue if it's a 365 instead of a 408?
If that makes you less cranky or grumpy, absolutely not.Well, might change it up a bit, I realized I have a rotating assembly allready done for a stock stroke 360 I was going to enter in a build contest that never materialized. Anyone have any issue if it's a 365 instead of a 408?
Sounds like a fun time, it will be interesting to see how much rpm some of these heads can support on a 3.58 stroke.Well, might change it up a bit, I realized I have a rotating assembly allready done for a stock stroke 360 I was going to enter in a build contest that never materialized. Anyone have any issue if it's a 365 instead of a 408?
If you care to run a set of stock eddy 5.9 magnum heads I would be happy to lend them. I have a magnum eddy air gap to use as well.
Sounds like fun!I may have to simplify the various heads to keep the variables more consistent. Maybe the first session I'll concentrate on the speedmaster, bloomer, edelbrock, trick flow and the pro max someone mentioned
Please give us your definition of baseline.If I had my motor apart I would send you a set of J's as a "baseline".. lol
The speedmaster and the pro max I believe are the same exact head.I may have to simplify the various heads to keep the variables more consistent. Maybe the first session I'll concentrate on the speedmaster, bloomer, edelbrock, trick flow and the pro max someone mentioned
i thought it was the same casting but the pro maxx has a proprietary porting program that gives it that exxtra?The speedmaster and the pro max I believe are the same exact head.
Hey why not call Dave at Hughes and see if he'll lend you a set of Big Mouths? If not I'm sure someone has a set of Eddy's with a murdered short side turn.
Didnt they have different levels of porting? Like as cast then “shocker” or something like that?i thought it was the same casting but the pro maxx has a proprietary porting program that gives it that exxtra?
either way, i'd like to see them stacked up against each other.
When somebody share's this type of info, no issues whatsoever.Well, might change it up a bit, I realized I have a rotating assembly allready done for a stock stroke 360 I was going to enter in a build contest that never materialized. Anyone have any issue if it's a 365 instead of a 408?
O RLY?Didnt they have different levels of porting? Like as cast then “shocker” or something like that?
Not the 2 in the pink 1 in the stink kind of shocker.O RLY?
in all seriousness, i don't have the slightest idea. i've only taken a cursory look at their wares.
