I'm all over the place with projects lol, whether its dash and harness, which means windshield removal(oh frickin boy) and SS trim upgrade from 67 nonsense. Removed rear pass side cargo light clip harness, and fuel sender harness. I got a new cover from
@Heywodja thanks!
harness were intact but VERY brittle. As was the bulb holder clip. Had to gorilla glue it in a few spots. Also got led replacements for the bulbs. Discovered the sender wire was pinched as flat as pi$$ on a plate at fuel line clamp on frame rail.
Surprised the fuel gauge still worked!
Gotta address the backup lights, I received another switch from Casey
@George Jets , so hope to remedy that shortly. Also mocking up the 273 adjustable rockers on the xheads. I need to do the DIY banana grooves on the shafts as these only have 1 lube hole(8 oclock position) Once I'm done the DIY porting on the heads, then new springs, locks, retainers to buy for my engine build(on the never ending shopping list)
Thanks all for help/advice.
**edit** if you look close at rocker shaft you can see I knocked the end plugs out for cleaning. Thanks to Roy
@SGBARRACUDA for posting Dorman # 555-011, RIP Roy.
Also you can see half moon shape approx 8 oclock(as opposed to the notch that I believe is more common and oriented directly downwards)
