I’ve never tried but they sell variable speed router controller.
Ones that attach to a die grinder? I've seen some that attach to dremels.
I’m just googling adjustable speeds for your die grinder. I have 0 experience.Ones that attach to a die grinder? I've seen some that attach to dremels.
To gasket match the area where the heads mate to the intake, you spray machinest dye on the gasket surface, then trace the gasket perimeter with a sharp scribe so you have an outline to follow.
Nice pics Doc. I cant' tell you if the porting is good but the pics are. lol. It looks like you did some serious opening of that port.
Want to keep some roughness to keep the fuel atomized.
I guess what I am saying is that I do not know if the areas that you removed the material from is what increases flow.It actually looks a lot smoother from the eye. Once you take a picture its easier to pick up on all the little imperfections.
Its definitely a lot more open thsts for sure. I think if I were going to want to use this port I'd just try to smooth everything and then trim the guide.
Are you getting advise on doing it right? No sense in practicing the wrong wayNeither do I... I just tried to make it look like the pictures on other FABO porting threads.
I'll probably start on port #2 this weekend.
Aluminum heads have the additional advantage of thermal dispersant capability; in other words, if you can run 10:1 compression with iron heads before you run into detonation, you can run 11:1 compression with aluminum heads on the same fuel, because the aluminum heads transfer more heat to the coolant jackets than iron.
