famous bob
mopar misfit
^dont like that stuff !
Chrysler didnt make or cut the rubber stuff , was ordered from a supplier , like most other parts of the car .
You are going to end up with hot oil on your foot, you really need to re-route the oil pressure line before it breaks.Rebled my brakes by myself... I wasn't to confident about pumping the pedal on the front brakes even with the speed bleeders. I'll test drive the car on the way to school tomorrow. I can't tell if the pedal is as stiff as it was before, I'll probably try and bleed them again after driving it a bit.
It'll be a quick morning at school since I only have to do a couple of easy extractions. Maybe I'll get done before Tony leaves the garage. I think I still owe him lunch
And yes, I know those are some white feet in some comfy slippers.... oh you were looking at the copper and black wires...
Better yet, an electric o/p gage.You are going to end up with hot oil on your foot, you really need to re-route the oil pressure line before it breaks.
Correct on the parts.
As for the beer. I used to drink a lot heavier beers and beers with more hoppe's in it, but my old age has changed that. I'll fill up to fast and get way to drunk way to fast lol.
I am getting there also. I don't drink as much but I now prefer quality over quantity. i wont go too cheap on beer. or whiskey.
i wanted to comment on the brake bleeding. If a one man operation I gravity bleed first. take MC lid off ,open bleeder, wait till it is running/dripping out pretty steady. close bleeder off. Put lid back on, pump pedal with bleeder closed. then open bleeder with MC lid still on, look for "bubbles" then steady trickle. repeat as many times as needed. OR as a modification to the aforementioned procedure..I pump the pedal with the MC lid closed, then put a pry bar or two by four wedged in between the seat and pedal, holding pedal down, then open bleeder. you can hear the air squirt out. Do that a couple of times then try the first gravity bleed that I mentioned. It usually doesn't take much time or fluid and you should get a good pedal. What you want to avoid is letting the pedal up while the bleeder is "open" it actually draws air in and you will be there all day. If bleeding all 4,start at the furthest and work forward. that would be Right rear, left rear, right front left front. I will sometimes open all 4 and let them leak on a gravity bleed. working alone is a forte of mine
Isn't driving these ole girls great!
You daily drive that?
Also... who is Dick Landy?
On occasion.
Who is Dick Landy ?
Oh man...... You are in trouble now.
Oh darn... another thing I'm doing wrong by not knowing dick Landy. let me add it to the list lol
Getting rid of some nasty vinegar water.... can't dump by house... we all remember the stained sidewalk and gutter incident... the drive to the dirt lot down the street was very slow and careful....
You absolutely did the smart thing by hauling it down the street! I've had a 5 gallon bucket of vinegar sitting in my garage for a few months, to use for derusting stuff. I decided the other day that it was dead, and needed emptying. I have a gravel driveway, and it has grass starting to grow in spots.....so I got the bright idea that the vinegar would kill it. Well, it worked like a charm and the grass is dead as a door nail. Problem is......it stinks to hell and back, and isn't letting up much as time goes on. DOH!!!!
