Johnny Dart
It was a grommet... now it's a torn grommet. I have a good amount of orings. Tore the thicker one as well trying to get it in. Ended up using a thinner oring that I could double up. The rod is all secured in the MC now.
Tell me you are kidding. You used O rings to secure the brake push rod ? You realize brakes are important right ?
This isn't time to be playing junior mechanic. This is now life and death for gods sake. You had the correct push rod grommet. It pushes into the MC with some lube and a socket. Its supposed to be a tight fit, as you don't want the push rod coming out of the MC. Do your family a favor, and do "this" job correctly. Please !!!!!
