Axle maybe slightly angled?
Lookin good!
What do you mean slightly angled?
Lookin good!
Rearend not being perfectly straight across may cause some "offset" like you measured.
Maybe you'll do better at pulling teeth than you do at pulling spindles!
When you try to get torsion bars out, take the bump stops for the upper control arms out so the arms will drop down a few more inches. That usually helps relieve more tension off the T bars so you can knock them out easier. I usually take the C clip out of the torsion bar socket in the crossmember, take the nuts off the LCA pin and the strut rod....and knock the LCA backwards until the torsion bar pops out of the back of the socket in the crossmember. At that point, you can get all the stuff loose. Hope that will help you next go around...lol.
As far as pulling teeth, my brothers method worked great! However old I was when my baby teeth started coming out, my older brother helped me pull them because I wouldn't let anyone else touch them. I was 6ish and he was about 16. He would tie a kite string around the very loose tooth, and tie the other end to a door knob of an open door. He would get behind me and hold my head still. If it was an upper, he would hold my head back. A lower he held it down with my chin against my chest. Either way, my mouth would be open. He held me pretty tight, and counted to three. When he got to 3.....I would kick the door shut and the loose tooth flew out tied to the string! It happened so fast it didn't hurt, and we would both crack up laughing! Every time we did it, our Mom would threaten to kick both our asses because we got what little blood that came with the tooth on the extractor door.....lol. True story to tell your Dentist buddies!
Speaking of extractions, I got my *** handed to me and then some today trying to get a tooth out.i ended up having to drill out the bone surrounding the tooth to get that sucker out.
Now that I'm all done though it's time to work on the dart so hopefully we can drive it next week. We will see!
