- Joined
- Dec 31, 2005
- Messages
- 8,198
- Reaction score
- 4,587
Guess that 195 cfm is the elephant in the room no one wants to discuss because........No, we weren't, but I was.
It's not the bigger or smaller, it changed their shape. I wonder how much power that engine would've made with traditional port clean up and no epoxy, all else being the same?Did that 10 pounds of epoxy make the ports bigger or smaller?
The heads went from 152 cc to 145 cc.It's not the bigger or smaller, it changed their shape.
What it shows is peoples adherence to dogma in the face of contrary evidence.What this thread shows how authoritarian peoples nature is it's all my way or the highway, no one with a each to their own mentality.
Using the 2.2hp per cfm, does it matter if it's 300 cfm or 195?Guess that 195 cfm is the elephant in the room no one wants to discuss because........
Nope. Look at Qwkmopardan who would have to be making 2 hp per cfm at least with his 587' headed 410 stroker.Using the 2.2hp per cfm, does it matter if it's 300 cfm or 195?
I'm talking about you too, I basically agree and disagree with most points being made in this thread. Depending on the context.The heads went from 152 cc to 145 cc.
Does the size matter if the desired flow is achieved?The heads went from 152 cc to 145 cc.
What you can do with less you can do with more.......I'm talking about you too, I basically agree and disagree with most points being made in this thread. Depending on the context.
You can't bring yourself to admit that as impressive what
can be done with these 302 heads that 360/5.9l heads would be better starting pkace especially aftermarket, that there would few reasons not to do so.
Still really can't this why it's 34 pages and countingWhat you can do with less you can do with more.......
That's a very good question. I can't answer it definitively but from the examples I've come across i would imagine that might be the case within "reason".Does the size matter if the desired flow is achieved?
Nope. If you can use all that 195 cfm what happens when you use more..........Still really can't this why it's 34 pages and counting
Just like others can't accept this build don't interest them but it maybe to others.
Sort of like modern engines eh?Don't you dare mention the efficiency of that head went way up raising the floor so the port has a more direct path/shot into the cylinder. Preposterous to assume anything of the sort.
Technically yes but reality no, efficiency is relatively narrow especially in the engines were dealing with 1-1.5 lbs-ft per cid and generally it's much narrower for the majority of builds.There's more to an internal combustion engine than just airflow.
YupNope.
So they increased the efficacy of the port by making it smaller..........Don't you dare mention the efficiency of that head went way up raising the floor so the port has a more direct path/shot into the cylinder. Preposterous to assume anything of the sort.
I still race a 318 small valve 302 4000Lb Aspen /Wagon with stock 390 lift cam and stock compression/
heads/manifold/ carb when I am not feeling good enough for the faster cars. I was shocked how well the stock 302 flowed compared to
my best 202 X heads up to max lift of 390 on the same bench even with the tiny valves (Hint: well over 200 CFMS's with the
right valve job.
The Wagon held the O/SA NHRA record @ 11.83 @ 109MPH. complete with Roof Race and Air Deflector
for years!
So when you throw a head that flows 240 cfm on that engine does that automatically make 480 HP?Technically yes but reality no, efficiency is relatively narrow especially in the engines were dealing with 1-1.5 lbs-ft per cid and generally it's much narrower for the majority of builds.
So air flow be it NA or power adder and NA gonna be ultimately through head flow.
I get what your implying still not exactly saying, it's ok you don't have to say, not twisting your arm.Nope. Here it is again: If you can use all that 195 cfm what happens when you use more..........emphasis on "use" and "more".
And?What size did GTXJohn say his heads are cc wise that powers that 4000lbs wagon into the 11's again? With only .390 lift as well.
No it takes the rest of the combo cam bore intake cr etc... But you throw on stock 318 heads will never make 480 hp NA no matter the rest of the combo is. The heads have the ultimate say how much power could be made if the rest is up to the task to extract max power.So when you throw a head that flows 240 cfm on that engine does that automatically make 480 HP?
A port don't flow 195 cfm's on the engine, that just telling you how restrictive that port is even if the engine displaces 800 cfm which is like a 460 peaking at 6000 ish rpm that only a 100 cfm's a cylinder but your gonna need a fairly big port and a lot of cfm @ 28" for a 460@ 6000 rpm even though the engines only displacing 800 cfmNope. Here it is again: If you can use all that 195 cfm what happens when you use more..........emphasis on "use" and "more".
Yep. .390 lift and over 320 duration, the gear, con. You know I always go on a car Enthusiast site we're 95% of the people are on the street and never at the track and then go on about heads that when modified a ton and a bunch of money dumped into can take you to the elevens in stock Eliminator racing.I get what your implying still not exactly saying, it's ok you don't have to say, not twisting your arm.
And?
It's a PDF link, I checked it, it's still active. It may be the browser or device you're using can't access or display it.Just state what the head being used is and stop using dead links. "about blank"
So that engine isn't using all that 240 cfm of flow? The Ultimate say is what you use. Those Underheaded combo's sure seem to punch above their weight and use all the airflow those engine receive. Here's an interesting aside Qwkmopardans 410 stroker with 587's makes what it makes with 28 degrees total timing.......No it takes the rest of the combo cam bore intake cr etc... But you throw on stock 318 heads will never make 480 hp NA no matter the rest of the combo is. The heads have the ultimate say how much power could be made if the rest is up to the task to extract max power.
125cc. That's even smaller than that 145 cc port. Still think a 318 needs a 160 cc port?And?
Its funny watching a daily driver street sedan that weighs at least 3400 LBS with a 318 and a tiny 218 hydraulic comp cam, stock converter and 3.23 gears run mid 12's with a 1.6xx 60 ft with only a stock valve sized 318 head.Yep. .390 lift and over 320 duration, the gear, con. You know I always go on a car Enthusiast site we're 95% of the people are on the street and never at the track and then go on about heads that when modified a ton and a bunch of money dumped into can take you to the elevens in stock Eliminator racing.
This guy was on a real forum were 95% of the people were Racers he would be stfu and not coming off like he is here.
His same old crap.. different thread.
Not what she said.Does the size matter if the desired flow is achieved?
