I give what is it ?What's the velocity in the port when the exhaust is pushing back into the plenum?
What no formulas and charts to tell what the reversion velocity is?I give what is it ?
No, So ? Point ?What no formulas and charts to tell what the reversion velocity is?
Why not? You think a velocity reading on a flow bench will magically tell you everything. Still deluded into thinking air flow is constant and one directional let alone what is happening in the cylinder during combustion.
I never made the case for importance of flow bench velocities, (That's DV and Chris) actually my point in this thread is somewhat contrary to DV and others.Why not? You think a velocity reading on a flow bench will magically tell you everything.
I do tell me more about how I think or know lolStill deluded into thinking air flow is constant and one directional let alone what is happening in the cylinder during combustion.
These aren't my formula's I ain't making the case that there 100% correct but they are used by some people in the industry one way or another.I have magic formulas........LOL.
So here is my take on the Boss Cleveland head port. Have the factory make them the size of the grand canyon, then let the racers epoxy to optimize port size. If it is a huge factory port, it's legal, yes? Most racers need to go bigger. Maybe Ford teams went smaller? I have seen many pics of heads all epoxied up raising the floor of the port.I'm not saying velocity not important, just for most part we have vary little control about it.
Plus look at the Cleveland and it 4 V head and 302/351 Boss these engines have to be one of the biggest examples of too much cross section for a given cfm for engines of small medium sizes generally not spinning the craziest of rpms.
Some will probably argue these engines especially the 302 are soft, but even if they are, these are some of the most extreme examples, the average small block Mopar can't even come close to over csa like the Cleveland. And there's got to be a ton of examples of strong running Cleveland based Fords out there. Not to say they wouldn't do better with an appropriate sized port. Point is a too big of port is probably better than to small for a given power. (within reason)
Most of us don't have the luxury to tailor match port cc, cas, cfm to each engine.
A stock X head can support 200-400+ hp engines, for a 200-300 hp engine a 273/318 head could easily do it too but gonna need way more cam over the X head which way is better ? On paper a stock 175 cfm 318 head should be able to make 400 + hp but is it the wises choice to do so?
On a single purpose race engine obviously the better you can match all this up the better the combo will be, a street engine that has multi-tasks to accomplish I feel velocity important but not at the compromise of everything else.
I agree a lot of race teams did that but your average builder didn’t and the stock engine definitely didn’t and they dyno higher than any of the other muscle car small blocks with a relatively small cam.So here is my take on the Boss Cleveland head port. Have the factory make them the size of the grand canyon, then let the racers epoxy to optimize port size. If it is a huge factory port, it's legal, yes? Most racers need to go bigger. Maybe Ford teams went smaller? I have seen many pics of heads all epoxied up raising the floor of the port.
I agree with all that you have said. Just chiming in with what I always thought and read.I agree a lot of race teams did that but your average builder didn’t and the stock engine definitely didn’t and they dyno higher than any of the other muscle car small blocks with a relatively small cam.
Why you straw manning me.Here's a thought. After you work out what the ideal port velocity
Both these are way low on my priorities.is then you can work out what the perfect fuel droplet size is to go with it.
Then after that you can tell me how you plan to control the size of that droplet?
Pretty awesome what some teams did with them.Found this on Cleveland Heads:
Even though a Cleveland head had great flowing attributes, they still received serious modifications. That’s why they were so dominant back then.
First, the exhaust side had 1.400˝ milled off. An aluminum plate that thickness 2 5/8˝ high was bolted in place relocating the exhaust ports higher. This was known as high porting. The original iron part of head port was welded or brazed and recontoured to match the plate port, making the exit as smooth and straight as possible. The longer you could keep the primary header tube straight off the port, the better the flow. A 19˝ long 1˝ wide X .250˝ thick steel girdle was used on top the aluminum plate. Torque sequence and poundage was also altered.
The intake port also had radical modifications. It was ported to the max flow and the pushrod boss cut through. Then braze or epoxy sealed that area. The intake rocker studs were moved over .250˝ to the right along with the push rod slot. The guides were plates cut, rebridged and welded.
Then blades were carefully installed in the port entrance to calm the turbulence. That blade installation had to be done on a flow bench. If placement was not perfect, it could ruin the efficiency.
Then we had offset dowels to index the head. We reinforced the headdeck by posting. Posting was drilling, tapping and installing 1/2˝ studs into the larger open areas in the head’s deck against the roof. Then mill the deck smooth.
Another must were the 3/8˝ load bolts from the outside ends of the heads through tapped holes nestling against the thin intake seats on #1 and #8 to keep them round. The work done in the combustion chambers was an art form. All was handwork. No CNC.
There are also things called: Roush type 351C-4V port stuffers. Essentially giving you raised port heads in factory style castings.
View attachment 1716267250View attachment 1716267251
That's what she said.sometimes little in the right spot is better than more in the wrong spot when working a port.
If you have reversion then you have the wrong camshaft.What's the velocity in the port when the exhaust is pushing back into the plenum?
I can hope he is meaning the sound/flow wave naturally created when the valve closes and the intake charge reverses??? Time that reversion with the next intake and you can overfill the cylinder. So choosing intake runner length, port velocity/size and cam shaft profile.If you have reversion then you have the wrong camshaft.
How about you tell us how port velocity changes during piston travel vs valve opening? Surely you have a formula for that too.....Why you straw manning me.
I'm sure both are very low on the "average" engine builders priority list too.....Both these are way low on my priorities.
Anytime you have both valves open after combustion has taken place means you'll have reversion. How much you have and how you mitigate it are a different discussion altogether. If the cylinder isn't filling it isn't making power.If you have reversion then you have the wrong camshaft.
The intake valve should be opening towards the end of the exhaust stroke. Then the remaining exhaust push will help create a vacuum to start the intake charge early and fill faster. Is this what you mean?How about you tell us how port velocity changes during piston travel vs valve opening? Surely you have a formula for that too.....
What's the pressure in the chamber when the intake valve opens? Theoreticals are not realities.The intake valve should be opening towards the end of the exhaust stroke. Then the remaining exhaust push will help create a vacuum to start the intake charge early and fill faster. Is this what you mean?
Do you hold yourself to these top 1% of builder (pro stock nascar f1) level of standards for your builds ?I'm sure both are very low on the "average" engine builders priority list too.....
What does that have to do with the average engine build most average guys will attempt........Do you hold yourself to these top 1% of builder (pro stock nascar f1) level of standards for your builds ?
It's how you look down at anything people are doing compared to these world class builders but don't seem to hold yourself to the same level.What does that have to do with the average engine build most average guys will attempt........
And ?The sharpest guys aren't reading DV.....
He generally doesn't make points or answer questions directly, he answer with question like he's a Professor or something trying to lead you to his point if he has one.The intake valve should be opening towards the end of the exhaust stroke. Then the remaining exhaust push will help create a vacuum to start the intake charge early and fill faster. Is this what you mean?
That's nice little summary, but so what, excess reversion is only a problem if you got an excess, and the power lost would have to be high enough compared to any gains from the mods, there's compromises to be made everywhere.What's the pressure in the chamber when the intake valve opens? Theoreticals are not realities.
Anytime you create conditions that invite reversion like bigger valves, bigger runners, bigger intake bigger carb and longer duration camshafts then you are not filling the cylinder no matter what theoretical air flow or velocity you measure on a steady airflow bench. Exhaust gases usually are innate but if you're making lots of CO during the burn that's a burnable gas that requires energy to burn again and that's diluting the next intake charge when it heads back towards the intake valve
