I understand 15's are a huge limiting factor, but i really want to retain my dogdish hubcaps. If i could fet 18s i could put dogdishdd on i would be sold.
Moog bushings are on the order list
Thanks for the rec on the sway bars, i will put those on the list.
How stiff are the mopar circle track springs? Are they just like a stock HD spring?
I looked through your resto thread alot, i wNted to pick out the exact same setup but im stuck with 15's. I really like your duster.
I have cooper Ultra Tourings on my 69 Valiant and they work really well for a 15" tire. Even in a straight line they hook better than the Mickey Thompson sportsman 26 x 10.50 I have for the car.
If you do run 225 60 15's they may rub on the front of your car until you move the fenders or set up the front suspension.
Fair enough. You'll want to setup closer to ralley setup than road course or even autocross. Autocross assumes relatively smooth surface, and gets some heat into the tires - also most competitors want a 'loose' setup which is not a good idea for real street use.Im not into drag racing, just want a car i can actually drive. We have lots of nice curvy roads, while im not exactly going to go autocross racing, I would like to be able to have a little fun in them.
It helps to know what your car weighs and how much is on the rear springs. Then you can get the height you want using rear spring rate and free arch. Options include:Right now i have SS springs in the rear. I would like something that levels the car back out and stiff enough to help in the corners. Any sug?
Probably a good move. 340 bars are OK with soft rear, but even on rougher roads, with todays tires, you'll probably be happier with a t-bar as stiff as 200 #/in or so.Right now i have 340 torsion bars. I am thinking 1.03 bars from pst.
Actually, a front sway bar is the most effective thing you can do. I'd start with that.Later on i wiould like to ad front/rear sway bars.
Basically yes. Good shocks are worthwhile, but not cheap. Front sway bar is a great bang for buck. Lowering the center of gravity and roll centers is good. Depending on your roads, 15" tires will be OK. If they're real bad, then maybe look at 15" rally tires, which provide pretty good grip over a wide range of junk, not cheap. Otherwise I think people have already provided good advice from their own personal experience. I actually run 70 series 14s on the street, 15s only for competition, but selection in 14s is worse than 15s.Am i on the right track for what i want to accomplish?
Cool, im a big fan of cooper tires, ill ditch the bf goodrichs and get myself a set of cooper ultra tourings. How does a set of 255/60r15s on the back on 15x8s sound?
Can you get them in a 255? I have 225 60 15's all around.
http://www.motortrend.ca/en/enthusiast/feature/consumer/1407-cooper-tire-cs5-tire-review/
a. Rick E-berger & Co. along with others have had good success in dearching SS springs for road course/street. Look up the Green Brick, especially the low buck approach they took the first time they were successful (not the first time).
b. Made in the USA replacements for A-Bodies based on factory specs from Stanley Spring. You may be able to buy locally. Here's a retailer that will ship http://www.stengelbros.net/Plymouth-Leaf-Springs_c_226.html Notice that Plymouth and Dodge had different leaf packages depending on the car's configuration.
c. A company like Firmfeel or Hotchkiss with strong interest and experience with rwd mopar handling who have developed options that generally work for people like you.
Do not add a rear bar unless you've added front anti-sway bar and preferably also increased the torsion bars. Do not add a rear sway bar if the rear is already very stiff. When the rear's rear roll resistance is too stiff relative to the front, it will have a tendency to fishtail rather than plow. This will happen when traction is lost, which of course is the worst possible time to find out.
For optimal handling yes, the closer the rear tire height is to the front tire height the better. You want the roll centers to be close.
The understeer can be corrected for if it's a problem, just run a larger rear sway bar. Or if it's adjustable set it more aggressively. Depending on your power levels it may not be a problem anyway.
We'll have to agree to disagree. Sorry. Just between my current fleet of mopars I've run half a dozen different brands of shocks, in suspension set ups that range from bone stock to basically full autoX. All run on the street. Even the difference between bilsteins and hotchkis fox's was far more noticeable than the battery relocation, and that was by far the smallest difference between all the shock combos I've run so far. Even just running on the street.
And tires are an even bigger difference. Even a small tire compound change can make a big difference, let alone width and profile changes. The entire suspension set up has to change around a decent change in tire compound.
For shocks the RCD Bilsteins would be fine. The Hotchkis Fox shocks are better for larger torsion bars like the 1.12's I run, but with 1.03's and those tires I think the RCD's would be more than up to the task.
Should i have just shelled out the extra $ for the hotchkis fox instead of the billsteins?
I know there have already been some suggestions but Anyone have any front sway bar comparison info? Cant decide the helwig, hotchkis or the firm feel.
I think he addressed this a little while back on the shocks...
All three have good hardware kits for a 74 duster with through the k-member sway bars.
Hotchkis is tubular/hollow, has nice stamped bar ends with formed cups, straight as it goes through the k-member.
Hellwig has tubular or solid. Bent through kmember for extra clearance. Bolt sway bar attachment hardware
Firm Feel offers solid. I think you can order tubular. Bent in middle and bolt in hardware.
Up to you to compare price.
