K.O. SWINGER
Meeting in the alley since 1976
Yep I definitely smell race gas on this one! Very cool stuff.
Yes Sir - even with decreased stroke , custom pistons with big domes going in ! Should have photos mid jan of engine going together .Yep I definitely smell race gas on this one! Very cool stuff.
It looks like the flow numbers are a little low on the CNC speed master heads posted for comparison, too. The effort on the Mullen heads does appear to be concentrated on the low lift flow. But it’s still preliminary as the valve seats need reworked to get them back to optimal. More to come, and many thanks to Chris for sharing! FWIW I’ll post up Mullen’s flow numbers from the Direct Connection “White Book” after I dig them out. To complicate matters there, the flow numbers are taken at a very low depression with the bench technology from 1975, so corrective formulas have to be applied for comparison. Even then, with such a large factor of correction at play, the margin of error will be on the high side for a true “apples to apples” comparison, but it does give some idea of what the heads flowed as delivered.Those are his flow numbers for the mullen heads? Disappointing.
Yes sir !Those W2 numbers look like a stock W2 head flow.
I forgot t
Look at the pics.Thank you - yes correct Oem 360 castings
I would start out with those and optimize the rest of the package. I would worry about upgrading the heads until after that “ONLY IF THE NEED ARISES”. The rules cap the class with ballast addition at around the 6.90 mark. It would think they would still be adequate for that with 12.5-13:1 and 3070 pounds race weight.Look at the pics.
They have offset pushrod holes, they are not OEM.
Dealer/factory performance part, yes.
I think the casting number is different than a regular 974 head, either way they've offset pushrod holes like a TA.
Thats why i say the numbers are disappointing. I and others can get 240's on average by .400 and 260s-270 @.500
They are very average heads. Historically significant, a collectors item. But for being an offset push rod head... they are barely worked.
Id use another head.
They'll work fine im sure, 400's hpI would start out with those and optimize the rest of the package. I would worry about upgrading the heads until after that “ONLY IF THE NEED ARISES”. The rules cap the class with ballast addition at around the 6.90 mark. It would think they would still be adequate for that with 12.5-13:1 and 3070 pounds race weight.
The numbers
.100-63.8
.200-128.2
.300-190.5
.400-229
.500-241.5
.550-241
.600-240.1
So it saturated some , but is not really backing up, and it picked up a good amount from .100-.500
Sorry I lagged on the update, I'm really busy
The ex numbers after just mild bowl ,ssr , roof n guide blending...I also laid the floors casting bump back.
.200-103-80%
.300-146-76.6%
.400-169-73%
.500-180-74%
.600-192-79.6%
As for using them or not.......
the work that was done........was done for them to be used.
Not to lanquish on a shelf somewhere on static display.
I’d def use them.
U nailed it , figures shown are on Conservative side - guy doing work doesn't have Roush type flow equipment but is a Very competent individualI suspect the intake short turn rework isn’t very aggressive.
The port certainly “looks” like it would flow more than mid-250’s.
But...... you’re also into the “racing flow benches” thing to some degree.
I’m sure, like myself, most flow bench owners don’t consider numbers from other benches to be “apples to apples” with theirs.
Aside from possible variations in the bench itself, there is also the fact that different radius plates/devices are being used by the different shops, which can definitely impact the flow numbers.
The intake ports on the Mullen heads look to have more rework done to them than the TA heads I went through this spring........ yet if we try and compare the numbers as apples to apples........ they would appear to flow less.
“If” that’s how it would actually go down if tested back to back(and I’m not saying it would)....... I can only imagine the short turn on the Mullen head needed a little more attention.
For comparison:
Lift—— in/ex
.100— 63/47
.200—130/99
.300—192/131
.400—237/148
.450—255/155
.500—259/159
.550—251/162
.600—253/165
.650—254/168
I guess what I’m saying is....... I’m giving Mullen the benefit of the doubt and that if I flowed that head on my bench....... I’d expect the numbers to be at least as good as the T/A head above.
Just don't hit'm with a piston or smash a valve impression into them. They'll be as worthless as all the 318 heads being melted into Hyundai's
My Mullen heads weren’t from the catalog, no offset pushrods. They were sent to his shop to be done. Not sure when, I was told early ‘70’s??
They are 63cc. 2.02 valves.
Photos:
I'm just going to say I really was hoping to see like... 300 CFM out of these things or something legendary.. from a legendary name , that's all.
I had high hopes that were crushed. Lol
I think i shed a tear when i saw the numbers, needed a hug.. lmao
Ill make it. LolIts ok - Get the wife to feed you grapes and rub lotion on your feet tonight and u will be ok !
One good thing pertaining to head flow is reduced CI so maybe overall they will be formable .
