Don’t Do This
TrailBeast
AKA Mopars4us on Youtube
Arizona
Sorry about the clarity as the original image was pretty bad.
Note the stack of adapters and fittings used for temperature reading.
I assume probably the very top sensor is for efi.
This setup is horrible, especially for efi as no gauge or sensor will ever get a correct reading.
Sensors need to be directly in the coolant flow, not 3 inches away from it.
That efi system will always think the motor is colder than it actually is, and not react accordingly.
Any gauges will read lower than the actual temperature.
Do whatever it takes to get sensor's physically in the coolant flow for accuracy.
Is there a large pipe plug near the heater hoses? That's usually the place for a mechanical temp gauge. And you can put hose adapters on that and have it inline on the heater hose.
I've seen stuff exactly like that and always scratch my head, because there's always a better way to do it. I think people try real hard to screw up sometimes.
Like R-Kelly once said “I don’t see nothing wrong” wait he’s in jail now bad analogy.
Don’t be a R-Kelly.
Haha…bad joke
I believe this is a /6 so who knows.
There are multiple ways of dealing with that.
I have had to do both our Mopar small blocks for mechanical gauges, so the tap is in the toolbox.
Both aftermarket intakes.
it's almost comical because there's four water ports on a big block waterpump housing
(granted two are for the heater... but who needs one of those?)
That could work depending on your setup (constant flow), but not if you've got a heater shutoff valve- you need constant flow of heated coolant to be accurate; valve closed=no flow=colder readings than actual.
Inline sensors also need to be independently grounded since the rubber hose provides no ground.
We used to do stuff like that on efi systems that weren’t tunable for the exact reason you said not to do it. We were trying to trick the computer so it would add fuel. It actually worked pretty good for how primitive it was.
I had to do something similar on my Durango with its 360 magnum and stock kegger in order to be able to put in an aftermarket temp gauge. No way around it on that one. Yeah it reads a few degrees cold maybe, but it's consistent.
I undid the nipple for the heater hose and screwed in a tee there.
Actually, having the sensor in contact with the spark plug wires is likely to cause more trouble than the slower coolant readings. You want those at least an inch and preferably a lot further from any wire going the ECU unless the wire is a spark output going to the coil.
That stack isn't ideal either; you're probably reading temperature through an air bubble instead of your coolant.
If I don't have room, I go to the block drain. Close enough for me.
