67autocross
A new iron curtain drawn across the 49th parallel
I won’t be using Doug’s headers I have never had trouble with TTI so I will stick to what I knowGreat! Maybe you can be of more help to the op when the time comes....
Hey we live and learn. There's a lot of people who have absolutely great success with those Doug's headers. (Burger King) < (LOL voice command) people say how they don't touch anything and are easy to put in..What I get out of all this is, if there is a good chance your going to have to beat the headers up just buy the cheap ones.If I had only Known.
I've had TTI's and Hedman Huslers. I'll take the Hedman everyday even if I do have to drill a hole in each side fenderwell. I spoke with Ryan Johnson years ago and he said the Hedman made more power than TTI's.
it's a sad State of Affairs at this day in age that they cannot make a header that fits. Lord forgive me for saying it but yellow rose has quite a point of making some headers that slip in much easier...The bottom line here for me is, I will buy the cheap headers next time as long as they are coated and have some sort of track record with end user's. After this nightmare with Doug's I can't see beating up 600.00 street headers.I just have a hard time thinking my car is some how this fare out of spec. I have done everything I can think of to fix this mess and have made a little head way but these things are going to hit the T/bars and that's it.I have raised the motor 1/2", New trans mount, shimmed it 3/8" up,there just to wide. Some say It can't be the TFS heads that are a little wider, I am at the point I just don't care. I don't drive my car's enough that a cheaper header would be fine in my case. A few year's ago I bought a pair of OGX long tubes for one of my Fox body Mustangs with GT40P heads and just a small dimple where the steering shaft comes down they fit really nice and are Polhised stainless steel for about 200.00. I think they had something for the A body if I remember right. I know I will get a hard time about OBX but that's ok.
I think a lot of times they are tacked together in a jig and then welded separately... Are these all high-dollar Union employees....FWIW, I had a brand new set of TTI W2 headers where the drivers side just did NOT fit. I'm talking with engine on stand, not in the car. I called TTI and discussed with the owner Sam, he indicated the headers are made on a jig and could not be wrong. He did however agree that it was strange they were touching both the head, and oil pan. He was kind enough to send me a second drivers side header at his expense, to Canada on my word. The new header fit perfectly. Moral of the story, anything can be made incorrectly, and TTI went over and above on their customer service. How it was made incorrectly still remains a mystery.
I have a brand new set to go on my Duster. Going to dyno engine with both these, and the Stahl headers it currently has.That Hedman is a good piece. Had them on the dyno and they work.
My favorite non W2 header is the Hooker 5303 which is no longer made. They couldn't sell them because A) they are slip together and 2) everyone says they are too big. Neither of which is true.
Upper photo is the Stahl set, lower picture is indeed the new set of 5303's I found. Sorry for any confusion.You sure that's a Stahl header in the bottom picture? I'm betting that's a Hooker 5303 header. I have to walk out and look at my header to say for 100% sure.
Also, I've found power with that Hooker header and a 3.5 inch collector.
How long before you make an entry on your own Thread about your build?...How long before you get to the dyno? This should be an interesting test.
Around FebruaryHow long before you get to the dyno? This should be an interesting test.
