Super-Cuda
MOPAR .. Move Over, Plymouth Approaching Rapidly!
Could notch subframe connectors , also I have seen were the exhaust is raised coming through the rear floor boards to exit is rear quarter before tire. Chris birdsong did that on one of his videos on you tube 69 charger looks awesome but it’s some work required.
Two things about that.
1. noise and heat generated inside the car,
2. In Canada, it won't pass a Provincial Motor vehicle inspection. USA is probably the same.
How about a square side exhaust tip ?
