I'm a chocolate chip cookie eater and there's no bad in the meatloaf made around here.. there's a vast difference between a thread for fun and a thread where learning is needed..
So what counts against the budget? Sawzall blades? I understand you've only had $1,300 into the budget but I just can't believe that building a separate motor to do all the testing and trial and error with gears and the body and all of that and the rear end doesn't count against the budget... it's easy to understand why you don't have tuning problems when you have stock compression motors with stock cams and stock ignition parts...
it's easy to understand why you don't have traction problems when you don't have enough power to break traction.lol..
I can hardly wait to see your 10 second truck in perfect tune... I can hardly wait to see it bite on the drag strip and pull the front tires up and get a 1.40 60 foot...
I asked you to stir the pot on mymassive reconstruction thread if you needed to. I was hoping to get help on my carburetors on the carburetor thread.. but you've heard me say that before...
