Dulcich 408 on dyno - offset heads
Hey! I’m so glad you got your W5 stuff up and running! Very nice. I’d like to request a better picture of the cams spec card. Also, can you show the head work involved? I remember you posted up some shots a way back.
Havent got so many pics of the heads. Here you could se the plastic fantastic. Will see if i could get some pics of the cam card. The heads flow at best 313 at 700.
Only got 1,5 ratio rockers.
You have gotten your ports very wide. Mine did t to so wide. Flow sheet by the head porters friends flow bench on a 4.125 bore plate. I have a ways to go on this project… still!
I was just gonna say, send me the bill when your done… but OK…
Looks to me like his ports are raised and shortened almost a 1/4” or so vertically and widened nearly that much. Should give a straighter shot to the valve with similar cross section as original?
I agree and probably.
Yep. Big difference making 1k with a hair dryer and doing it NA.
Not really. Torque is torque. Its real easy to detonate a turbo motor. Detonation is what kills blocks, well and brutal torque. The wives tales about what blocks break at are false. I made 800 on nitrous with a cast crank 360 and it lived for years that way.
That’s great. Man your tune must be spot on! Thanks for the info.
My tune was really a mess for a long time. But the things I am super careful with are timing and fuel. Some people think I am too conservative but its what makes stuff live and I cant afford to throw money away because of impatience.
Those are very impressive numbers! I couldn't agree more getting greedy for an extra 30 or 40 horses or whatever and ending up with a garage full of oily scrap iron it's just not worth it.
