If can find some Formula V traction treatment it works wellInteresting, which ones work? I have tried everything under the sun and stopped doing it about 5 years ago because nothing made a difference.
No one I know treats the tires, just not effective. If it was, I would do it and there is no reason to hide it.
That's what you meant by treating the tires? Yes, for sure the traction compound and the rubber on the track help out traction............. You are the winner of the day!Just not effective huh..thats funny my car hooks much better on the track then on the street why??..cause' the track is treated with sticky compound!!
I read it as treating the tire…Tires that are treated with sticky compounds far from what came stock!!
The FAST class cars are hooking due to suspension setup / weight distribution/ cam grinds that push the power into higher rpms and softer low ends / timing tricks / tire shaving and many tricks I haven’t even thought of .Just not effective huh..thats funny my car hooks much better on the track then on the street why??..cause' the track is treated with sticky compound!!
I was standing at starting line when they ran at Cecil County. Yes track officials sprayed the track down with sticky stuff. Track was continuously cleaned too. When officials saw FAST cars about to stage looked like they sprayed a bit more sticky stuff on track from what I saw.....Just not effective huh..thats funny my car hooks much better on the track then on the street why??..cause' the track is treated with sticky compound!!
I assume this is your car?...Very nice work!The thinking game is what keeps me interested in the class. I'm constantly trying to improve the car or engine in some way. The ideas are getting harder to come by, and I am not sure how much more I can get out of the combo without stretching or disregarding the rules and intent of the class as some have been doing recently.
I’ve always been curious what would be the best combo with a similar to FAST spirit. As in I have a 72. Run 68-70 manifolds. Then whatever year has best intake, whatever year has best carb, etc.. It’s not all year correct but is factory stuff and to the undiscerning, not noticeable. Of course not FAST legal, but that’s something I’d be interested in finding out and doing someday. I would think 72+ would be good for the intake and carb due to higher rise but I’m no expert. Congrats again on the new record. Making us Mopar guys proud to seeWe built a 71 because of the intake and carb for sure. Whether it is the ultimate setup, I don't know. Quickest stock eliminator to my knowledge is a 70, and they don't even have to worry about the exhaust manifolds.
Makes sense. Lots of considerations. I’ll just enjoy watching FAST from afar. Keep up the good work.That's a rabbit hole you can spend a ton of time in. 71 has its advantages but also disadvantages. Good carb and intake, but bad exhaust manifolds. Grille has to be sharkstooth which is heavy, dash has to be Rallye which is heavy..
Man when the weight of the grill matters you are right on the edge.That's a rabbit hole you can spend a ton of time in. 71 has its advantages but also disadvantages. Good carb and intake, but bad exhaust manifolds. Grille has to be sharkstooth which is heavy, dash has to be Rallye which is heavy..
And Vettes came with the biggest tires of any 60/70s muscle cars .It's all a balancing act of everything. Dumbing down the torque and trying to hold on to the power as high as possible. Getting it to set the tires without hitting them too hard, converter, pinion angle, instant center, all are big. I'm in the stone ages with ignition and timing curves, I just use springs in the distributor to delay timing.
I agree with you with the vettes, they took a killer package and then tweaked the rules so the only limiting factor left is the tires. No one is going to catch up.
It’s just and L42 auto car but is in great shape.
What are you waiting for?I know where there is a 73 Vette with 50k original miles that I can buy pretty cheap and am half tempted to move on
Im out of room to be honest .What are you waiting for?
