I’m just saying there’s some great builders that transmissions are just a side gig. A guy with a lathe and a vision can create some pretty cool stuff. Don’t try this at home kids!! Some dark ages stock eliminator stuff ;)So what are you saying ?
He is saying there are some great builders out there who just work in their own garage.Agreed ............ but still a little confused
He saying there are some great builders out there who just work in their own garage.
Thanks I try. LolAnd i think i agreed . And by the way nice lookin work .
If you look in my signature I think there are still pics of my rollerized components.Holy krap! we have a rocket scientist in our midst! Cool stuff Duane!! Thanks for sharing.
the “Swiss cheese” direct drum came out of a trans I bought from a friend who bought it….. I wish I had more picts from it. There was a lot of time spent lightening components. Probably not the safest deal, but still pretty cool.
I may not know everything about rebuilding transmissions but I look good doing it...….and I still confess I know enough about torqueflights to make me a danger to me and others close by, but the fun of helping a dejected friend make the call to quick 16 the next day using swap meet parts is a lot of fun
The exact point of the thread/forum...Not hardly rocket science, more like copy cat
and not being afraid to try.
one key element though, have you ever stayed at a holiday inn express?I may not know everything about rebuilding transmissions but I look good doing it...
So do you build in subassemblies ?So to recap if you're rebuilding the entire transmission you're going to want to replace the brass bushings if they have uneven wear or any wear... I've done it many times without doing the brass bushings so they usually look fine.. the rebuild kit should have all new rubber seals and ring seals and also new clutches and steels. At this point if I was rebuilding this as a long time keeper I would change all that stuff but as it is everything is looking good and I'm just going to put it back together. I will get a new front seal and rear seal tell house and gasket and front pump gasket. Also a front pump lip seal likely...
So I have to work tomorrow but Friday I'm going to dedicate to cleaning the front pump and the drum right behind it. After cleaning I will assemble those...
Absolutely.. I keep everything in order... I will clean and reassemble the first two parts and place them in order on clean paper towels... I'll continue like this until all the parts are back in order cleaned and reassembled in order. Then I'll give the case and tell housing one final clean and start assembling things back the way they were..So do you build in subassemblies ?
