Johnny Dart
sounds good
This isn't far from what I have in the Demon; 302s & Performer on a 318. I'm @ 218/228 @ .050 and .441" lift. I'm also using a 625 cfm AFB. Also went to 67-70 spec stock pistons for higher compression ratio. I would expect your setup to have better top end, while my forte would be throttle response at lower speeds. Which is better? Depends on how you plan to use the car most of the time.Edelbrock Performer intake (or maybe a Weiand Action Plus), Holley 670 carb, a set of "302" heads that will be gasket matched, Summit G9040 1-5/8" headers and dual exhaust, and assuming I have a 8-1/4" rearend I'll go with the sure grip carrier and probably go ahead and change the rear gears. I was also looking at the Comp XE268H (20-223-3) camshaft with 224/230 dur @ .050 and 0.477/0.48 lift. Assuming this is what I go with, does anyone see any major problems with this combo?
Any suggestions on the rear gear?
What did this car run at the track?????ET
60 foot time???
WHAT MPH?????
I would get a cam with about .440 to 455 lift and a tight center line of about 108...
...I would run a cam that is in the range of 218 to 225 @ 50.
Ok, so does anyone know of a cam with similar specs to these? I'm not finding any cams with around a 0.450 lift with a LSA of less than 110°. It doesn't appear that you get down to 108° unless you get over 0.475 lift or so. Or maybe you were referring to the "Intake Centerline" vs. the "Lobe-Center/Lobe Separation Angle"?
As I've explained before, I'm a bit of a noob when it comes to all this, so I'm just trying to get my terminology down.
Headers and 4 barrel intake with an 850 Thermoquaker really woke up my 72 318 , not a waste at all , kept up with firebirds and camaro. 318 has always been underrated , it's a good little motorJMO. Unless you go with a little bigger cam, a 4 barrel is a wasted effort on a 318.
Check out the Hughes engines for they're Whiplash Camshaft....Ground on 109 degree...Made for low compression engine, raises cylinder pressure, and from what the video shows it has a nasty chop to it.....It was in a 340 but the guy had comp listed at 8.5....I talked to a rep and that's the cam I'm goin to put in my 318....
Oh, I saw the video and was definitely impressed. The cam just seems so much larger than the other ones that have been recommended. I guess I owe it to myself to call them and find out what the deal is
What do you mean by "air up cyl"? How do you do that?
Take the new set of heads to the local machine shop and have them cut .030 thousands and and about .036 on the intake side of the heads.
Just tell the machine shop you want .030 off the heads and they will measure and cut the intake side however much they need to.
Ok, forgive my ignorance again here, but when you say to take .030 off the head, are you talking about removing that much material off the "bottom" of the head where it mates to the block? If so, wouldn't this screw up how the intake aligns with the heads?
And I'm guessing the point of this would be to increase the compression ratio?
