The prices are published on their website but it was like $150 to narrow the rear and $350 for new axels. I added billet axel ends also which was another $90 I think.How much did it cost to have the axles and rear end narrowed?
Awesome, thanks!Yep, unclamp the back and add a clamp to the front. That's what worked for mine. Of course I'm not running any boost...... yet.
What do you guys use for clamps?Yep, unclamp the back and add a clamp to the front. That's what worked for mine. Of course I'm not running any boost...... yet.
Was this pass with the new single plane or you still running the airgap?New personal best. 7.26 98mph
My 60' approved but still leaving some on the table I think. This is after adding the leaf sliders and clamping the front of the springs.
Still running the Air Gap. Only changes were to my suspension. It definitely hooks now, though a little slow getting out of the hole since I'm only foot braking it. As soon as I figure what the f$%^ is going on with the Fitech tune, I'm going t turn up the boost and then maybe switch to a single plane.Was this pass with the new single plane or you still running the airgap?
the AFR is still incredibly lean. 13.20:1 gas scale with 27* timing, 7 psi.
Not sure if this is testament to the tolerance of E85 (which I measured at an honest 85%) or I've just been incredibly lucky that there hasn't been any detonation or worse. Regardless I can't turn up the boost until I get this Fitech tune squared away, but this gives you guys a good idea of the kind of power you can get from this junkyard 5.9 combo with EBay turbo gear.
Yes, I know. I've maxed out the VE tables under boost and am still running lean. I'm overlooking something else. Maybe I'm not getting enough fuel.I'd say you're damn lucky you haven't melted a piston yet.
I said this to you before, you need to get the Fuel Map corrected such that the Fitech doesn't have to ADD huge amounts of fuel but is REMOVING a 5-10% Fuel
Only if the Injector Duty cycle is Maxed out(>90%) AND/OR the Fuel pressure is Dropping.I'm overlooking something else. Maybe I'm not getting enough fuel.
Yeah, thanks. I need to rule out the fuel pressure. That one is nagging me as I don't have a reliable way to measure it under load.Only if the Injector Duty cycle is Maxed out(>90%) AND/OR the Fuel pressure is Dropping.
Thanks for chiming in Matt. I think it must be electrical also. I'm running the pump off of a relay that ties straight to the pos side of the battery in the trunk. I'm going to try moving the ground from the pump straight to the neg side of the battery and not the frame where it currently is. I believe I have enough alternator (120amp) but I should add up my total load. Aside from the Fitech and fuel pump I run a single Chevy HHR electric rad fan. I'll measure my voltage at the pump also. AEM says it needs 13.5v ideally.Any voltage drops at the pumps? Can you alternator handle the load for higher psi along with everything else you have on the car needing amps?
For example on my build I have 3 fans on radiator, 2 fans on heat exchanger, the pump for the air/water ic, the fuel injection, normal car demands and also for a meth pump which I still may or may not use, two fuel pumps I had to get a 200amp alt to support it all.
