In case you didn't know, You can watch the timing on the digital gauge display. It will increase with RPM depending on the settings you programmed such as 35* all in by 3000rpm.View attachment 1715242399 500 plus miles. Flawless. Need to learn new fuel tank and how to be sure that vacuum advance is working on freeway for increased range.
Wow this thread has really got me excited for the Pro-Flo. I am about to install an FiTech as I’ve done with many other projects but mpfi has it’s obvious benefits. What I don’t read is anyone using the Pro Flo is how do they run? I’m big about performance, how is throttle response and power vs your previous setups?
Agreed, I’m running a small block as well.One the guys here posted his Big Block running the Pro Flo and he said it was great. I'm hoping someone with a small block running a Pro Flo will chime in.
It should be better than carb or TBI, cant think of how it wouldnt be.
Ill find out in 6 months, ill let you knowI'm just curious to know if it will fit under the hood of a Duster. The intake is taller, but the throttle body is shorter than a carburetor.
if you have a look at my earlier Post #58 in this thread I’ve provided some info to help regarding comparative height of this unit. I’ve still got a way to go with the build of my car before it’s running but here’s another photo of my ProFlo4.
I went with Mega Squirt 3 On a stroked 440 making 600 plus HP. I have never looked back! Love EFIHave you browsed the Edelbrock Forums? Last post from an E Body owner. Check it out.
Any problems with the new Pro Flo 4? - Edelbrock Community Forum
When you look at the all in price not so much different. Even with the kits you have a lot of 2nd and 3rd tier costs that no one ever adds to the "cost" of the kit. If you look close at pix down on frame rail you will see the coil packs. And yes they are LS ! No distributor at all ! Had to make crank trigger and a couple other sundry parts. There is enough you tube and forum material you can sort out the how to relatively easy. Biggest issue for me was sorting out kick down! It self learns and has made the car way more consistent than I am. I initially had a serious issue with breaking loose on big end going into third. You can readily see it on the laptop. With old setup I would have been messing with rear suspension etc etc. to solve. Simply put I think the new EFI kits are amazing and as long as you get a good one you are fine regardless of brand. The-positive change in my E body as a result is what drove me to stuff a gen three in an old Demon I have. I have a seperate build thread with a bunch of pix for that build here on FABO. I try not to focus on the E body on this forum as it is FABO! And most of the E body forums are dominated by purists so my hybrid Cuda is of little interest. It has a 70 nose, 71 sides and 73 tailights! Roll bar and EFI. I wish I had a dollar for every time I take it to a car show and had to answer how could you do that to a Cuda.Nice! I was looking at the MegaSquirts but it seemed like it could end up more expensive, but at least you can customize pretty much everything. What did you do about distributor timing? Seems like 440's get more EFI love than small blocks. Even the B blocks are left out in the cold.
