View attachment 1715076757 View attachment 1715076758 theses are the bushings, Hey Rusty when was the last time you have seen one of these?
In a vehicle.....a WHILE.
What's the point here? Do you feel that 8* initial is a good setting for an engine?
26* mechanical is an absolute POS for anything mopar, even a stock 318. Unless you plan on running 40* total timing, then there's a chance.
But then no one man has all the best answers.
What would he say about all of us loving our abodies?Dr Phil sure as hell thinks he does!
This +1Yeah? Then read his description. He says his distributors are to be set at 8* BTDC. Hardly a performance oriented curve. I think what he knows more is how to fleece people out of their hard earned money while giving them an absolute minimum performance product all based on his"fame". Sounds about right to me.
This +1
Get an OEM Mopar one from the for sale section or Old Car Parts Northwest, or one of the newer Mopar ones they used to make if you can find them, and then recurve it.
Or get a recurved one from a member here such as @TrailBeast
i read that as 12 @ 650 rpm,24 @ 950 rpm,26 @2500 and 34 total @ 3000 rpm
looks like a good curve to me or am i reading the description wrong?
Jimminy Christmas
26* mechancial advance, which is what this wonderfully useless distributor in OOTB form has, is not going to be good for anything mopar built that you'd expect to run well at idle and 34 total... is that better? 8* initial timing is ABSOLUTE GARBAGE. 8 + 26 = 34 Is that a good enough explanation why the curve sucks ***?
He mentions "For most setups you'd want to run initial timing at around 8 crank degrees BTDC." On what fricken planet is that good advice? Not planet Earth. Not even stock 318's like 8* initial. Maybe a smog tune up, then you aren't buying that thing either. Then just change the mechanical advance in the ad (crazy hot cam), on a distributor which it's not real easy to do... hmmmm.
I wouldn't spend that amount of money on a distributor, especially if it can be found for less money elsewhere needing the work that's required to run in a decent mopar engine. Garbage is what it is in stock form.
I thought he said 8 initial at 650 rpm for ease of starting,but by 950 rpm his 2 stage springs have added 16 for a total of 24 degrees.
That's pretty quick, do you guys run more than 22 degrees at 800 - 900 rpm?
for a guy that has built,raced and taught mopar performance for 60 years i can't believe there would be any detractors.
i doubt if there is a more dedicated Mopar Enthusiast.
