bkd
No more Scoops
FANTASTIC!!!!! I'm so happy for all of you GREAT news
The engine harness was mostly intact when I got the car. I decided to run Flamethrower HEI pretty early on in the planning of the project. I left all of the circuits intact in the harness and made most of the required changes to run HEI right there by the ignition box. I picked up the blue and brown start and run circuits right there and sent them over to the HEI Module. From the module the distributor pickup is wired direct and a short jumpers go from the coil to the module. I then used one of the harnesses unused ignition leads to send the negative side of the coil back over to the terminal block to connect to the tachometer pickup. Only thing I needed to disconnect was the Mopar ignition connector from the harness, which I would have had to do if I stayed stock ignition because it was crushed and mis-shapen anyway.What are all the wires next to the washer bottle?
That Duster really stands out in the crowd......bet you get a ton of "thumbs up"
No wipers?
No wipers?
LMAO. When you have to search you are done!I know they're never done but I wish I was as close to done as you. When you get to where you have to search to find things, you're there. Glad your son is enjoying the journey too!
Amen KeithLMAO. When you have to search you are done!
As a drivable car, I consider it 'substantial completion'. Say 'it's done' out loud and **** starts blowing up and falling apart!
I was going to ask you about that tool. How does it work?Buy the tool from Mancini racing, in and out easy, less than a 5 minute job.
What fan are you running now and why do you want to change?So back to the fan and shroud. I think I'm going to buy that shroud and an OEM metal fan. What happens if I don't run a fan clutch? Should I have one?
