Turbo440Dart
crank runner over-er
What are you using for a boost controller?
Just a manual turbo smart controller for now.
12psi is going to be a huge jump in power. Can’t wait to see numbers…and hopefully video!
I need to wrap my exhaust and put blankets on the turbos on the boat. I melted the skin off both biceps at the lake yesterday working on it. Definitely not fun.
Yea it’s been hot. The lake was beautiful yesterday, but had a rocker noise and a small water drip from the for/rev cable I replaced. Boat life. I unfortunately got both arms in almost the same exact spot. Turns out turbos make heat, who knew?This is the perfect weather to wrap exhaust in. The heat really helps me not get irritated haha. Hope the arm is alright buddy
What heat wrap are you using? I need to order some. And I need to find blankets for the 78/75s
Thanks. I’ll probably get the blankets from him as well but I’ll have to cut them for the wastegates since they’re welded to the turbine housings. That DEI titanium stuff is expensive.
Ouch! Looks as fun as Harley drag pipe burns. Grab some aloe vera plants....Yea it’s been hot. The lake was beautiful yesterday, but had a rocker noise and a small water drip from the for/rev cable I replaced. Boat life. I unfortunately got both arms in almost the same exact spot. Turns out turbos make heat, who knew?
Great idea, I think I’ll try that. I ordered two blankets from VS and the whole DEI titanium kit from summit.If you gotta trim them I’d try to find the thread the use on them and sew around the cut, they might come apart if you don’t.
Yeah, it wasn’t cheap but I had a summit gift card so I figured I’d get something semi useful for once.
Thanks took me a few times to get it to lay right then putting the SS zip ties onThat looks great!
I use the cheap generic fiberglass stuff off Amazon. I’m amazed at how much heat it holds in, but I’m told the DEI is better.
That was quick. Props to Summit.
Noted.Don’t do what I did with the stainless ties. Feels real good when they go under your nail and make you bleed.
Looking good. I almost went that route as well, they are a pain to use.View attachment 1716119755
First one done. It’s such a shame to cover up stainless tig welded exhaust but my skin will thank me. Oh by the way those stainless zip ties can kiss my ***. They don’t work and I threw them in the trash after I tried to use the first one. Made my own out of stainless 030 saftey wire.
