grassy
We didn,t blast the trunk,we had replaced a 1/4 panel with trunk extension(left part of trunk at the seam)I,ve also done a minitub,so yes sealer was removed at the time of doing the work.I replaced the sealer when I was done and will do it again before paint.You should leave yours in to keep the factory look.If not,scrape it out,then reseal.
Thank - you.
We will just touch up the sealer with sandpaper so the paint will stick.
ian
