AdamR
Big Member
Krusty the Duster is up for sale. Just lost interest in old cars.
73 Duster, Solid Cali body. No rust any were. 318, 904, 7 1/4 rear
Originally F8/F8, Power steering, manual disc brakes. Big Bolt pattern. Fold down rear seat, factory rear defroster.
The car was stripped to bare metal, Sprayed with 2 coats of epoxy then blocked with 2K over and over and over.
All Jams are in primer except the engine compartment which I can do. I do need to prime the entire body once more and wet sand it to make it ready for paint.
Bumpers are ok driver quality
All glass is good
What the car needs
A complete interior. All the plastic panels were cooked from the hot Cali sun
The seats have been recovered and are in good shape but are gray. They could easily be dyed. Cardboard headliner is in ok shape.
Engine and trans are ok but need to be new gaskets
Engine harness has been splice more times then Im comfortable with so I would replace it but it could possibly be fixed.
Suspension could use the usual bushings.
Door glass rollers need to be replaced
Parts included
Car has a new Pypes 2.5" X pipe exhaust off the factory manifolds
New Firestone tires, 14X5.5" BB Rallyes
I have the following parts not on the car
New POS battery cable
DMT body gasket set
New Gill Hardware
Good set of used factory exhaust tips.
73 340 4bbl intake
73 340 4 speed thermoquad (needs rebuild, apart)
extra thermoquad parts
72 340 flapper aircleaner
Edelbrock 600cfm performer carb
Im asking $3750 firm as is, Car in primer ready for paint.
I can have the car painted in the color of your choice for an extra $2000
Or I can finish the car to your specs for an agreed price.
If your on the East Coast this car will save you thousand on body work and paint. You will not find another this solid. I have tons of photos. Car is Located in Bethel CT 06801 about an hour from NYC, 2Hrs from Mass.
Feel free to ask any questions.
All glass is good
What the car needs
Parts included
DMT body gasket set
New Gill Hardware
73 340 4bbl intake
