Treed!Might be for an ashtray light
That would be great! Thank you! Would you mind taking a pic of your engine ground?Let me know if you want a pic of the light switch plug. I can get it for you tomorrow if you want.
You're doing great so far, learning new skills and working out the problems.Haha! Thats a must!
Yes, that engine ground is pointless, it should go directly to a hole on the firewall, and yes it and the headlight ground must be to bare metal.That would be great! Thank you! Would you mind taking a pic of your engine ground?
I’m pretty sure mine is grounded to a bad spot and it’s a very thin wireLet me know if you want a pic of the light switch plug. I can get it for you tomorrow if you want.
Thanks a million! I feel like a pain, but don’t know what I’d do without the help on here. Pretty amazing stuffYou're doing great so far, learning new skills and working out the problems.
Thanks. This guy sure messed a lot of things up. I’m told that grounds are super important on these older carsYes, that engine ground is pointless, it should go directly to a hole on the firewall, and yes it and the headlight ground must be to bare metal.
That may be difficult..................That would be great! Thank you! Would you mind taking a pic of your engine ground?
Hahaha!! That’s awesome!! I definitely should be able to help you out on some things when I’m done this damn car. lol!That may be difficult..................
You'll be able to help me out when that time comes.
I'll get that pic out to you tomorrow.
Thanks a lot for the message. I’m trying to keep positive! Some days it’s tough, mostly because I paid for and expected a finished, show quality car…..not a project car of poor quality. But one day the car will go to my kids and it will all just be an interesting story!dads71, im sorry your going through this with your builder but i commend you for the way your solving each new problem as it arises, I am lucky to have a very knowledgable friend that lives right down the street and he helps me all the time, sometimes i feel like a pain in the *** but in the end he helps me work through each problem. FABO has so many helpful members, dont be afraid to do exactly what your already doing, these guys help me all the time , im very grateful. Your car and your story are amazing, dont give up, one step at a time. I will be following along as you work towards that first ride in your Dads 71, he would be proud!...Rich
Sounds good. I’ll check that out. It’s new, but you never know!Check the headlight dimmer switch on the floor. I’ve seen it cause all kinds of problems if not grounded.
Yep. For sure!Progress! Every little success is a great day.
Glad that person's description clicked with you. Different peaople have different ways of learning, or respond better to different explanations.This post made a lot of sense to me. I can’t find who posted it. Maybe I found it during a Google search
Thanks. No denying your knowledge! I appreciate the help a lot!Of course its not the dimmer switch. That's makes no sense.
[/URL]
Sorry above was the best I could do.
Two of those circuits use the headlight switch, turn signals do not.The headlights, signal lights, dash gauge lights aren’t working.
You don’t think it could be the dimmer switch then? My actual headlight switch is new as well. But this black wire was hanging beside it. Not sure if it should be pushed into the harness or pushed onto the tab on the switch. I’m also wondering if the wires are in the right positions within the harnessOf course its not the dimmer switch. That's makes no sense.
[/URL]
Ok. Sounds good. I’ll try that tomorrow! Thanks! I forgot to mention that the horn isn’t working eitherTwo of those circuits use the headlight switch, turn signals do not.
I would start where you know there is power and then follow each circuit until you get to connections that have no power when they should.
If it was me, I'd start by testing the horn or measuring voltage at the alternator stud with the key off.
Voltage at the stud means there is a connection through the main splice. We kindof know that because the car starts. Blowing the horn sends power to the horn relay. That's better proof of a good connection. Observe the ammeter - it should go to discharge with the horn blow.
Then check for voltage on thealways hot buss of the fuse box. Then check the output side.
Now here's a problem with voltage checks. Just because there is a connection doesn't mean its a good connection. When current tries to flow througha poor connection there is resistance. You won't know there is resistance until turning something on. Lets say the fuse has poor -oxidized contacts. Turn on the parking lights and the votlage on the feed side fuseholder is 12.3 V and on the downstream fuseholder is 6 Volts. Now we know there is poor connection. (This was a recent FABO diagnoses)
Also, I don’t have the cluster or dash installed, I just have it sitting on a towel on the steering column. But I did add a ground wire and connected it to the underside of the dash. I’m reading a lot of stuff saying that lights etc won’t work unless the cluster assembly is fully screwed into the dash. But a ground wire should do the trick for testing, no? I just didn’t want to put it fully in until I know it all worksTwo of those circuits use the headlight switch, turn signals do not.
Now here's a problem with voltage checks. Just because there is a connection doesn't mean it’s a good connection. When current tries to flow througha poor connection there is resistance. You won't know there is resistance until turning something on. Let’s say the fuse has poor -oxidized contacts. Turn on the parking lights and the votlage on the feed side fuseholder is 12.3 V and on the downstream fuseholder is 6 Volts. Now we know there is poor connection. (This was a recent FABO diagnoses)
Yes its possible, but probably not a harness problem, but a bench test problemCould one issue cause all of these not to work?
There's a lot garbage online too. Since you want to bench test, you will have to make sure the circuits have a return to the power source. Your challenge will be to understand each circuit you are testing. The horn uses a relay. When you look at the circuit, I suspect you'll see the horn doesn't work because either the circuit to trigger the relay or the circuit tp power the horns is incomplete. Maybe both.I’m seeing a lot of stuff online about bad grounds.
My goal here is for you to decide that yourself if that makes sense. ie. The best thing I can do is help you learn.You don’t think it could be the dimmer switch then?
Look at that terminal and compare it to the proper terminals. I don't know what that wire is yet, but doubt it will stay in the connector.My actual headlight switch is new as well. But this black wire was hanging beside it. Not sure if it should be pushed into the harness or pushed onto the tab on the switch.
