B
Area 51 or groom lake facility as its also called has a bunch of radio active toxic waste there or so they said while watching discovery channel on this. Go tromping around there, and get cancer or some other ****. No thank you.
Spaceship didnt land, it supposedly crash landed in Roswell NM in 1949 I believe. Its speculated that the ships pieces and alien bodies were taken to area 51.
Think about this for a minute. In 1949 jet aircraft travel was in its infancy. They were starting to use them and tinker with them in 1939, the Germans used them towards the end of the war with the ME262. The engines hot section (turbine) metallurgy at the time wasnt good enough to handle the temps that ran thru it. They required a lot of preventative mtx to keep them flying
So in 1959 Lockheed's skunkworks develops the SR71 blackbird reconnaissance aircraft because the U2 being basically a powered glider was a sitting duck flying around up there. They wanted something that was really really fast. The SR71 project was kept pretty clandestine for years before it's actually announced roughly 10 years later after it's been flying. It's pretty ironic that this aircraft started flying missions a mere 10 years after the Roswell crash. Is it possible that some tech was picked up off alien craft??
I am sure Lockheed's engineers at the time were smart, but heres an aircraft that flies at 2,800 MPH , and at 80,000 feet above the earth where you can see the Earth's curvature and the boundary between Earth and space. All this and only 10 years after the Roswell incident.
This is something to really think about.
some, SOME of the tech came from previous research and the engineering cane from operation paperclip-not all were rocket scientists
If you read military history, even just the tidbits they leak out , the concept for the stealth bomber/fighter angles came from Russian research which was stolen by our spies.
There are YouTube videos covering OLD 1950’s video footage of the SR-71 construction, other than the jet engine performance, and mastering a titanium frame/shell which expands with heat and contracts in cold, the technology isn’t beyond belief-
That being said, the fighter jets from the same era even into the 70’s were pathetic tech compared to the blackbird.
Lockheed Martin has always had the brightest minds and top government funding which leads to success-far ahead of the competition.
It’s other tech, like electro-static, gyro-navigation -which was several decades before satellite verified positioning, and other military tech that is mind blowing: lasers on the front of 747aircraft to shoot launching icbm’s, lasers from jeeps, using miles of fiber optic cable to shoot several miles away, rail guns, Chinese sound weapons focused on individuals, or just the satellites that handle billions of streaming selections of shows...
