GermzD74
Cool Member
Well the gas gauge hasnt worked ever since I bought the car...
Great news! Got it to move! lol
I am so close to being able to drive the dart to work once again!
I sure miss it!
But I have one problem with it!!!
I took out the instrument cluster, to check the gauge out...everything was okay, tightened the gauge lock nuts a little bit, along with the temp. gauge ones...the gauge now moves, but there seems to be a problem
The temp and fuel gauge needles go all the way up!!!
So I untighten the lock nuts a lil bit and the gauge's screws, tured on the ignition half way and the temp gauge stayed put and the fuel gauge seemed to stop where it should...so I turn the dart on and then the lights...and bam! The needles go up all the way again...
I dont want to mess it all up nor waste time, what am I doing wrong!? How tight should the nuts be, or...is something on backwards? A wire not pluged in all the way in?
Or maybe its the red and black amp wires...I put them back on, and hand tightened them only...IM SO CLOSE! :cheers:
I sure miss it!
