Ironracer
Gearhead
Yeah, don't sound like lifters tiknScuffed the skirts.
If it were liftersbit would sound higher pitch, a tic but somewhat more robust.
https://www.amazon.com/dp/B0002SQYSM/?tag=fabo03-20Longest I have is a 10". Should I go pick up a longer one? Or can I stack them? Lol
You put the extension behind the ear. On your skull...brotherThanks! Went out with the 10". Almost sounds like the lifter valley/ cam chest, but that's with a regular ear. Haven't found anything with the ext. Yet.. did lay hands on the fuel pump. Not sure if they are supposed to have a noticeable "hit" when you grab em w/ the mill rollin.
Oh man. It's got an 8 qt pan. And the damn poly motor mounts are not fun on one side. Everything is tight in there. Lol. ( former B body guy) I've owned a bunch of /6 A's. But just drove em. 63 Dart Gt, 71 Demon, a few Dusters,, a 68 Valiant 318...anyway the tip on locating that sonically is much appreciated! So what would cause piston scuff?I'm not the final say, just a prediction.
Maybe you'll see piston to head contact. Idk the motor...but if it was scuffing you can see it from the bottom/ oil pan side.
With a stethoscope you will hear it prominently around the plug area on the cyl head. You won't hear much if at all at the pan rail .
AHH, Thank You, Brother! My hearing ain't as bad as my eyes, but I see the theory! Get the Noggin Knockn'You put the extension behind the ear. On your skull...brother
I haven't tried to spin it manually that far... or do you mean kill ignition, and roll em w/ starter? It a low mile build, w/ all good parts... but that prolly don't mean much. I think I'd hear the Cloyez hitting...haven't checked for chain play yet. NOW, on that fuel pump eccentric, when she's running, I can feel a solid "hit" when I put my hand around pump. Not sure if that is common. But, it's not " un time " w/ " the sound" or how that would transmit...is there a way to test that? Man, that would be a Blessing if that was the case!!!!!!!Does it do it when you rotate the crank? Fuel pump eccentric hitting the timing cover? Does the crank turn a few degrees before the chain tightens up? Could be whipping to the side of the case?
Cool. Motor was on points for 2 years. When I tested the Hi Rev dizzy, I don't think I had enough vacuum to pull in vacuum adv. And I haven't drove her much maybe 25 miles ( after a thrash for the rear suspension, and adding stripes, for a friend's Memorial, and another 18 miles to go to ( now x) moms for Thanksgiving. Other than that, just some 3 -5 jaunts through the area out here. Do you need a better Spark Plug Pic? And Thank You for helping me. I may be screwedToo much timing for too long, spark scatter/bad rotor phasing.
OK. I know I sound ignorant somewhat, but I'm gonna do it anyway! Lol am I looking to push up and down, in and out, side to side? And how will know if it's moving o the cam? Im a Carpenter. Maybe, sometimes, at best, a " parts changer". Definitely NOT a diagnostic Mechanic/ Tech. Thank God I've always drove Mopars.. I'd be screwed otherwise!if you pull the pump and jam a screwdriver in there and rattle the eccentric around, it should not move on the camshaft. If it does...its loosey goosey.
Yessir! I'll pull the pump tomorrow, after work, and report back. THANKS AGAIN!timing cover off.....that means balancer too. Water pump too unless you want to remove the radiator and pull the pump with the case as one piece.
You'd think. Let me ask this. Let's call it a knock for the sake of naming the noise. Is it one knock or does is sound like all 8? You say it's diesel sounding so that would sound like all 8, right?If the Eccentric was spun, wouldn't lose fuel pressure/ operations?
What does it sound like when completely warmed up at operating temperature? Does the noise subside any?Yessir, I reckon. I mean, I held my hand over the fuel pump, while running, there was a noticeable "hit" felt that was over the engine shaking, but, it was not " In time " with the Constant " sound " like a bad drummer, practice n syncopation.
Honestly, Rob, i haven't got her up to op temp, in a while! Did a shifter, front end, and then caught that **** dizzy issue. However, I was mapping timing the other day, with my gal reading tach, and operating throttle, for a bit. It Seemed to be quieting.. but I wasn't specifically looking for/ at that. And I didn't look at temp ga. But we mapped it, several times, up to, and over 3kWhat does it sound like when completely warmed up at operating temperature? Does the noise subside any?
Nowhere near warmed up. If it's what I'm thinkin, it's gonna quiet down significantly when it's up to temp.Well, I have a temp ga on er. Today, running it, the wp was still disconnected. Was maybe 140 on ga. Never ran it really long, at one time.
