Ironracer
Gearhead
I'll get my 3rd arm to give me a hand!can you shoot a video in the fuel pump hole while your holding a flashlight and bumping the starter relay with your 3rd arm? that would show you a possibly wiggling timing chain cog.
No Sir. Was a video of the car running. But the fuel pump.arm.is loose by 1/4"! I can grab that suckered and, with No Problem,.wiggle it back and forth.. Praying that's it
They must be around .004-.006
I like them on the street at .003-.0035
Just got back from a Friend's place. Borrowed a stethoscope and a endoscopic gimmick w/ a side scope. Gonna warm her up and listen after pump goes back on. Getting dark though. May get some lights.. did the screwdriver in timing cover, all is tight there.. except fuel pump. Now I'm second guessing myself. Was the fuel pump the noise? And I'm a hearing rockers rubbing now? Or did nothing change?It's not the valvetrain.
I ran it without it... I gonna have to do it again. It's definitely got some sound still...maybe less sound..Run it without the fuel pump.
Cover hole with cardboard and bolts just o keep chain spray in.. it will run on the fuel bowls for a min. Enough to tell it's not the fuel pump.
Man, just run it until it croaks. Then the cause can be determined!Im stumped.
Sounds good. But with pricing and parts availability, I'd be as done as the engine. I could never get it back togetherMan, just run it until it croaks. Then the cause can be determined!
Are the pushrods clearing?
Only valley tray is bottom of the intake. Never thought of pushrods rubbing .. what's the best way to eliminate/ check that? And wouldn't that have been there always? I wish there was a Mopar Ear near. LolAre the pushrods clearing?
Check'em, after that... might have to pull it apart at least the heads to see the cylinders. And is there a valley baffle tray used? They require Clearancing
Well, they were New MP. HD units. I used a book to put em on.... now when you say " swapped" do you mean bank to bank? Or dig up some 318 stockers, or did you mean I got the R @ L swapped during install? At this point, I ain't ruling nothing out. And this " sound" I did notice awhile back. I just want to find out what it is, and rule out Anything that could cause CatEngFailCould the rockers be swapped?
Interesting Steve......Is it an optical illusion, or does it look as though a couple of the rocker tips are not centered over the valve?Could the rockers be swapped?
